counter-stear or lean?
RE: counter-stear or lean?
I have to make a little more effort to use the counter-steer method on my RG than the last bike I had (Vulcan Meanstreak) it was lighter with a smaller front tire, that bike was more nimble, andfast to start a corner. I do believe everybody does it, they just dont know what it is.
there was a video of a test bike where the guy had 2 sets of handlebars, one was fixed. the idea was to show folks how countersteering works, and leaning doesn't. a bunch of folks who said that they steer by leaning found out the hard way that leaning didn't get them squat..... yes, they were leaning, but countersteering got them turning. they were just leaning in response to the bike leaning into a turn. not vice versa
Soooo.. Say you are riding rather fast down a paved road with lots-of twisties (counter-steering hard)... as you are going through one of the curves,the pavement ends, and there is loose gravel for the final 15 feet of the curve. You can't slow the bike down because there is several bikes on your tail, or change your lean angle cause of a drop-off on both sides of the road. Would you still counter-steer or try leaning? Which wouldkeep the bike in the track with min.slipping on the loose rocks?
ORIGINAL: Barebackjack
It's pretty scary to think about all the people that are riding m/c's that don't have a clue to what they are doing.
As has been pointed out in several posts above this one, there are a number of techniques that are employed to make the bike turn in the way the rider want it to. Everything starts with countersteering but applying extra weight to the inside peg or footboard and/or shifting your weight to the inside of the seat all help the process.
Ride Safe,
Steve R.
ORIGINAL: Ultra_Bob
In that case, what difference does it make if you countersteering or use a weight shift method? Since you can't change your lean angle either way, I'd say you've already screwed the pooch and it's time to bend over, kiss your ***, and pay the piper!
I've been in loose gravel before on the Goldwing I used to own. I never actually dropped it but I sure thought I was going to until I got clear of the gravel. The point is, if you don't have enough traction to maintain balance, like on a heavily graveled road, you're probably going to drop it regardless of how you think you're steering the bike. Countersteering is and always has been the primary means of steering a motorcycle.
Steve R.
