05 ultra classic ignition issues.
Good evening, I have an 05 FLHTCUI ultra classic that will die (quite a bit) during a ride, but start immediately upon cycling the run off button while I’m still rolling in gear.
Radio stays on, seems to only be killing ignition. I pulled a Po1353 and 1356 (no ignition front jug or rear jug, respectively). Bike runs perfect t otherwise. No alarm system
im thinkin the tip-over sensor, or a relay that gets reset after cycling the run stop switch on the handlebars.
thoughts?
thoughts?
I spoke to the owner who says the bike has fallen over to rest on the crash guards (foot washed out in a parking lot due to loose gravel) and the bike stayed runnin. He says he didn’t notice any lights on the dash.
I can’t get it to cut off by laying it over on the guards,
it only does it while riding. Seems to idle in N fine. Maybe fuel hose in tank??
Why would loss of gas cause loss of spark? Assuming codes are clue. I have tipped bike over many times, and it does seem tilt is erratic. Though I also think you reaction is to turn off , and not always paying attention. So one time I did it see, and it did say tilt. Point is, not sure it bank sensor.
I did have issue with houses when half full on my 2007. Only did half full. Not that, is a guarantee.
Is he restating with ignition switch or kill switch? Though bad kill switch should not throw a code, I would think. But would have lights on with engine off. But I think lots of things could be causing this.
I am pretty sure it has a main fuse. But he said the radio would be on. So electric is not cutting out He is losing spark or fuel. Codes say spark, according to him.
Ultrascott (09-06-2024)
it restarts immediately upon cycling the kill switch on the bars. It’s weird as hell.
I suggest something entirely different as the root cause...Dirty/sticking IAC.
Crankcase venting goes straight into the intake behind the filter and gets the intake assembly all gunked-up over time.
If the AC assembly hasn't been off for a while, then I strongly suspect this to be the culprit.
Pull the air filter assembly off and look at the cleanliness of the butterfly flap and surrounding areas/surfaces inside the intake throat.
Then shoot a lot of MAF cleaner (or similar) into the hole on the roof of the intake throat.
That shoots cleaner all around the IAC plunger/spring.
If the above is at fault, then the engine will often hunt for idle and die after coming to a stop. It will restart as if nothing happened.
It will not do this if you simply start the bike and let it idle.
HarleyReece (09-08-2024)
