Can I remove this bolt?
I took a look at the service manual. In my case the 2011 Touring Service Manual, Chassis chapter, rear fork section. I see no reason why you can not remove the screw (fork bracket screw) to delete the tag.
It indicates 2 drops of blue Loctite before installing it.
2.21 REAR FORK, Installation/Apply two drops of
Loctite Medium Strength Threadlocker 243 (blue)
to threads 55-65 ft-lbs
GalvTexGuy (08-23-2024)
Just giving you hell, pull the bolt and then put it back. Your bike won't explode, it'll be fine.
It might not explode, but you might want to tighten it to torque specs and, as mentioned, put a couple of drops of blue Loctite on the fastener.
steelpony16 (08-25-2024)
An easy to remove bolt on plate is generally not permitted for an inspection sticker in many places.
Reason: Because it could be removed and placed on another bike.
Rather weird because so many parts of the bike can be removed.
Some plates are designed for the sticker to cover the bolt and those may be accepted but it depends on your area.
Received 1,633 Likes
Received 21,949 Likes
