Crazy anyone price a rear brake job on a Touring bike lately?
#31
#32
#33
The one and only time I had a dealer do brakes on my '93 Ultra classic, they messed it up. They couldn't figure out how the anti rattle clips went on, so they left them off. It rattled like a set of morocco's. I had to go back and they gave them to me to install them. Since then, I buy pad's online and put them on myself when they're needed. I take the front calipers off, press on the lever a little bit to push them out, spray the bejeebers out of them, then clean and grease the pins up to remove any crud remaining, then compress the pistons, and grease the back of the pads. I grease them with silicone brake grease, slide them back in with a bit of anti seize on the 1/4 inch screws and the fronts are done. The back pads are a bit trickier, but being patient pays off. Pads are cheap enough to replace when the tires are changed, so paying dealer prices for brake pads aren't worth it to me. I never had any issue with aftermarket pads.,,
#34
This is what I perceived on newer style I pulled the caliper to install tire. It looks easier But on old style you don't need to remove tire as said. Even with a big touring fender I do it I suppose maybe some real big fender could block view? The touring bikes the fender is not whole, but cut out on sides too. But we are in the touring section.
#35
#37
I don’t think so. EBC pads are generally known to be made in the UK and possibly US? If you look at Harley’s box it says made in Japan so I’m leaning more Tokico or Akebono?
Even if they were EBC (I don’t believe they are) I wouldn’t have gotten the paste, new caliper bolt, and a new caliper bolt clip for double the money.
#38
#39
#40
Received 49,832 Likes
Haven't used the Harley "Goop" yet ... During my years operating an automotive garage I had a chance to get involved with GM Proving Grounds on several occasions ... One in particular was the newly designed ( 1988 ) Cutlass / Regal "W" car ... I had been using Disc Brake Quiet and I was introduced to Dynatex ... In short order it became our "go to" whenever a brake job was performed ... It significantly ( if not completely ) reduced brake noise ... It doesn't wash out and also does a remarkable job of keeping all external moving parts moving freely and clear of rust ... Still use it to this day on ANY brake project ... " Try it, You'll Like It "
https://dynatex.net/products/brake-s...-compound/109/
