Street Glide vs Standard
Old 08-31-2007, 08:52 AM
motorjon68's Avatar
motorjon68
motorjon68 is offline
Default Street Glide vs Standard
How big is the difference in ground clearance in corners between these two? May be my deciding factor.
Old 08-31-2007, 09:22 AM
gunrunner's Avatar
gunrunner
gunrunner is offline
Default RE: Street Glide vs Standard
Only difference in street glide over other touring models is they run 1" shorter rear air shocks.
Old 08-31-2007, 09:27 AM
pkenyon1's Avatar
pkenyon1
pkenyon1 is offline
Check the brochure, in the back it gives you all the stats etc.
I dont have one to hand otherwise I would let you know.
Old 08-31-2007, 12:04 PM
PREACHER's Avatar
PREACHER
PREACHER is offline
Sit on or ride both bikes. Your body will tell you which one. I would say go with the SG but that is the one I liked the best. I think the SG seat height is one inch lower but that is probably because of the shocks.
Old 08-31-2007, 12:07 PM
gunrunner's Avatar
gunrunner
ORIGINAL: PREACHER
Seat on street glide will lower you another 1" or more being less thick than the standard seat too. Harleys site gives seat height on SG at 26.3 and standard at 29.3, but suspension wise they are only 1 inch different due to rear shocks.
Old 08-31-2007, 12:26 PM
rome304's Avatar
rome304
rome304 is offline
sg is a footrest scraper love it.
[IMG]local://upfiles/22213/312B32075D0A43668E33EBDE8E55F1BD.jpg[/IMG]
Old 08-31-2007, 12:44 PM
I SPY's Avatar
I SPY
I SPY is offline
I do most of my riding in the mountains andhave a tendency to hit those corners pretty hard, so I wanted the extra height that the FLHT provides in order to minimize scrapping the boards. I believe that the seat on the standard is also a bit thicker/taller.You might want to make your choice based onyour physical stature and style/location of the majority of your riding. On the other hand, there are always mods..... You're gonna like which ever one you choose. Have fun!
Old 08-31-2007, 12:53 PM
mistermooster's Avatar
mistermooster
mistermooster is offline
Having had both SG and EG, I'll say this: For cool looks, the SG has it, and for solo riding it handles great! You may scrape the footboards once in a while; no biggie. If you're going to do much touring, or two-up riding, the EG has the edge.
Opinions may vary
Old 08-31-2007, 04:27 PM
BOARGAURD's Avatar
BOARGAURD
BOARGAURD is offline
I just couldn't get comfortable on the SG with the smaller floorboards, so I went with the Standard. Sure I don't have a black motor but it still looks cool to me.
Old 08-31-2007, 05:04 PM
dansflhti's Avatar
dansflhti
dansflhti is offline
I think that the standard is one of the best buys out there....but i'm biased.
Quick Reply: Street Glide vs Standard
