Oil Change issue
RE: Oil Change issue
Hold on guys, BillyO, the peacemaker here, We are all in the same small boat. As for ********--every body got one. You guys should be punished and made to ride a SUZUKI.
Put FOUR F$%^&*@ Quarts in.
The way I do it is to fill up the filter 3/4 way and put thr reest in filler hole.
I wouldn't worry too much as to the amount you put in, just the proper level. Warm the bike up. Leave on jiffy stand and drain. Pull the filter and replace. I usually dump 3 quarts in, start it up for a couple of minutes, then check and fill to proper level (on jiffy stand). Keep in mind mine is an 05 so check your manual to make sure it is the same procedure. I also check the level again after a couple of decent rides.
ORIGINAL: Bryan TTM
exactly...another stupid *** question....done it before huh
ORIGINAL: NICK56
GEEZUS just put the 4 qts in and ride the bike!
If u put 5 qts in it wouldnt matter !
