Anyone price a 3 hole change at the dealer lately?
Old 04-10-2024, 08:55 AM
r0de_runr's Avatar
r0de_runr
r0de_runr is offline
I was on a trip last May and paid $154 for just syn3 oil and filter change at the HD Dealer in Jackson MS. No primary or transmission, no service, just the engine. I thought that was high. But I guess not. I was pushing 6k miles on that oil.
I usually always do my own.
  #32
Old 04-10-2024, 09:17 AM
Sethc1020's Avatar
Sethc1020
Sethc1020 is offline
Originally Posted by Cle_rider
Bikes with ABS required the Harley tech tool to cycle the ABS valves. Simple, yes, but need the right scan tool.
Thats what they tell you but you don't from my understanding. I used a vacuum hand pump to pull the fluid through the system, filled the reservoir up around 3 times for each caliper to make sure all the old had cycled through. There's plenty of videos on Youtube how to do it. I also like to utilize the ABS system after the flush then flush one more time to make sure all the old its out. Simple and very easy to do.
  #33
Old 04-10-2024, 09:32 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,166 Likes on 3,675 Posts
If I was in a trip with a fresh oil change and mostly hwy miles on full synthetic oil I would go up to 10000 miles on motor oil no problem. I would bring some with me but I wouldn’t worry about it.
  #34
Old 04-10-2024, 09:39 AM
Pantera99's Avatar
Pantera99
Pantera99 is online now
Received 1,145 Likes on 649 Posts
Exactly! Have one very similar & its adjustable to almost any filter. I usually just make everything hand tight & try to remove the same way but this has certainly helped when they need a little coaxing.
  #35
Old 04-10-2024, 10:03 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,378 Likes on 4,784 Posts
no way in Hell I would go twice as long as the manufacturer states...protective oil additives diminished, filthy oil filter and air filter....that 10,000 miles could be chuck full of airborne contaminants and hot temps that would be a problem, to me anyway.. others may be less discriminating
Rydefree (05-24-2024)
  #36
Old 04-10-2024, 10:40 AM
Germansheperd's Avatar
Germansheperd
Germansheperd is offline
That’s a good tool but I’m not sure it would have been enough on this one-maybe.
  #37
Old 04-10-2024, 10:47 AM
Germansheperd
That is high
  #38
Old 04-10-2024, 10:50 AM
ybnorml's Avatar
ybnorml
ybnorml is offline
Received 29,086 Likes on 11,627 Posts
Figure 1/2 hour shop time plus cost of oil, filter and o-ring....
  #39
Old 04-10-2024, 10:56 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
well that seems about right..our dealership sells a qt of SYN3 for ~$16 same for the oil filter..so they are going to charge you 5 qts & filter..6 x $16 = $96 so about $60 for the labor to change the oil..I would think most folks would expect a dealership service department to charge ~ $50 to perform that service ..especially if on the road and it needed it and you got a quick turnaround, would be worth it imo
ybnorml (04-10-2024)
  #40
Old 04-10-2024, 11:08 AM
702's Avatar
702
702 is offline
Received 5,828 Likes on 2,385 Posts
The 1/2 hour doesn't give them time for the upsell
The following 2 users liked this post by 702:
Pappy35 (04-15-2024), ybnorml (04-10-2024)
Quick Reply: Anyone price a 3 hole change at the dealer lately?
