2002 road king handle bars
Old 08-29-2007 | 12:19 PM
wolfy's Avatar
wolfy
Stage II
Default 2002 road king handle bars
I own a 2002 Road King, I have replaced the stock handle bars with stock chrome bars. Problem is the new bars do not stay tight, they keep dropping.
I noticed the new ones have a straight knerl, and the stock have a criss cross pattern. Could this be the problem?When I took it apart I also noticed my riser bushings are shot. Two part question:
1. Why do the bars keep dropping, and how do I cure this?
2. What are the torque specs for the bar clamps and the torque specs for the riser bolts
Old 08-29-2007 | 12:30 PM
bezoar's Avatar
bezoar
Default RE: 2002 road king handle bars
Could be the worn down knurl. You can try what I used to do and that's slip a small piece of rubber on the knurlked portion of the bar and tighten. The rubber keeps it from slipping. Oh and torque specs for the bar clamp---tighten the **** out of it!
Old 08-29-2007 | 12:43 PM
I am Jerry's Avatar
I am Jerry
I had the same problem when I put the bars on my Classic, It's a bitch to have to go back in there to do anything. I found a couple of very thin star washers in my junk drawer and put one under each top clamp, against the barsand tightened the *** out of it. No more problems.
Old 08-29-2007 | 12:47 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Did you replace the upper clamp when you changed out the bars??? If not... That could be the problem... The OEM upper 2 part clamp are junk as it doesn't grab the replacement bars as well as the 1 part clamp...
Old 08-29-2007 | 05:53 PM
DragonNester's Avatar
DragonNester
Since you don't have a manual, and you should, this is out of the manual:
Tighten upper handlerbar clamp screws as follows:
a. Tighten front screws until upper and lower handlebar clamps make contact.
b. Tighten rear screws to 12-16 ft-lbs.
c. Tighten front screws to 12-16 ft-lbs
Note: A slight gap will exist between the upper and lower clamps at the rear of the handlebars after tightening.
Old 08-30-2007 | 02:39 AM
PapaTravis's Avatar
PapaTravis
I have the same problem with my apes. Not a big deal, yet, but does bother me. I asked a question here about it, and was told to try a piece of sandpaper wraped around the bars. I haven't tried that. I also contacted the bar maker, and he suggested to use a clamp that has set screws in it. I believe this to be the best solution, but have been unable to find a top clamp with set screws. I have decided that since it is not a real big issue, I will wait until winter. What I plan on doing is taking the one piece top clamp off, drilling two holes in it, and threading the holes. Then I will add a couple of screws to it. Should work okay, and seems like a better fix.
buffettphan
07-10-2018 08:26 PM
apetterez
10-28-2014 07:20 PM
grizz57
09-13-2011 03:25 PM
flpops
09-05-2007 03:24 PM
jbrooks
04-04-2006 01:02 PM
Quick Reply: 2002 road king handle bars
