Little help cleaning Brake Calipers
Old 08-28-2007 | 09:09 AM
beary's Avatar
beary
Default Little help cleaning Brake Calipers
Hi All
Can someone give me the torque values for the caliper bolts and brake pad pins? My front brakes on my 02 RKC are squishy and after doing a search, I decided to start with the easiest suggestion first; pull and clean caliper pistons. Took about two hours I guess because I had to figure out how to extend two pistons at a time. Next time will go faster, but now I need to tighten and loctite all the bolts. Should Igrease the brake pad pins?
Thanks ahead for your help
Beary
Old 08-28-2007 | 09:36 AM
flashprez's Avatar
flashprez
Default RE: Little help cleaning Brake Calipers
two bridge bolts--28-38 ft-lbs
pad pins--180-200 ft-lbs
bango bolt--17-22 ft-lbs
bleeder valve--80-100 ft-lbs
saw no grease on brake pad pins
Old 08-28-2007 | 09:42 AM
Dr.Hess's Avatar
Dr.Hess
I think you mean Inch-Pounds on the bleeder valve and pad pins. 100 Foot Pounds would snap that bleeder right off. 200 ft pounds is starting to get to what the crank is torqued to.
Old 08-28-2007 | 09:52 AM
flashprez's Avatar
flashprez
You're right, my bad. I just got carrid away.
Pad pins--180-200 in-lbs
Never learned to read lol
bugs-06
Wheels/Tires
04-16-2011 02:41 PM
myking
Wheels/Tires
01-31-2010 05:54 PM
swwilson77
10-20-2008 04:07 AM
bucs012
05-12-2008 11:12 AM
bucs012
05-12-2008 09:07 AM
Quick Reply: Little help cleaning Brake Calipers
