Hydraulic Clutch Installed
Old 11-22-2005 | 06:35 PM
Cache's Avatar
Cache
Default RE: Hydraulic Clutch Installed
Dont' the '06's come with a hydraulic clutch?
Old 11-22-2005 | 09:26 PM
pococj's Avatar
pococj
I have a Rivera hydraulic tranny cover in the for sale forum, if somebody wants to save some bucks.
Old 11-22-2005 | 10:33 PM
gsparesa's Avatar
gsparesa
ORIGINAL: Upswept
Yes, the White Brothers kit is easier and cheaper. But, with the WB kit, you still have the clutch cable and it's routing which is very ugly on the Road King. The hydraulic clutch eliminates the cable and gives you a new generation clutch which has been on other bikes for about 10 years.
[sm=smiley25.gif] You still have to route the hydraulic line. Are you saying a hydraulic line looks better that a clutch cable?
Old 11-22-2005 | 11:41 PM
Retired_Ted's Avatar
Retired_Ted
ORIGINAL: gsparesa
ORIGINAL: Upswept
Actually, compared to the cable, the hydraulic line does look better. First of all, it's very flexible and therefore can be routed through the top of the headlamp nacelle and out the bottom - under the right engine guard. There's very little visible near the handlebars which suits me fine since my wiring is all internally located inside the handlebars. Isn't the WB kit nothing more than a centrifugal clutch, btw? Like my old go-cart used? Just curious.
Old 11-23-2005 | 02:02 AM
Gillty's Avatar
Gillty
Stage II
'06 come with a reduced effort clutch, not hydraulic...i compared an '05 to an '06 clutch during my last visit to the dealer and it is noticably easier and lighter to manipulate. Almost, but still not to the level of a hydraulic clutch which I also tested.
Old 11-23-2005 | 02:26 AM
gsparesa's Avatar
gsparesa
ORIGINAL: Retired_Ted
I would call the WB Easy Boy Lite Clutch a torque amplifier.
It lengthens the arm on the inner ramp of the clutch release cover assy. The increased length increases torque because it moves the cable contact point further from the fulcrum.
Old 11-23-2005 | 03:16 PM
Upswept's Avatar
Upswept
Yes, gsparesa, the line looks better. On the Road King, the cable is attached to the left side of the headlight. When you turn left or lock the forks, the cable buldges out. With the hydraulic clutch, and especially with a black line line I got, the hose is routed along the handlebars and into the headlight shell. I bought the black/chrome unit, hydraulic hose (black), and the master cylinder cap kit. All three, with a 20% discount, totaled about $425.00. I did the labor.
Old 11-23-2005 | 09:55 PM
gsparesa's Avatar
gsparesa
Never noticed that on a Road King before. Interesting.
Ron750
11-20-2015 11:33 AM
Jeff's 1st Harley
11-28-2013 08:46 AM
Columbanus' assistant
Shovelhead
11-26-2013 11:52 AM
biker girl
08-07-2010 08:26 PM
pro1955
05-12-2006 01:56 PM
Quick Reply: Hydraulic Clutch Installed
