Notices
rivet tool
Old 08-26-2007, 12:31 AM
rustyhd1948's Avatar
rustyhd1948
rustyhd1948 is offline
Stage II
Default rivet tool
[:@]need to know what i can use insted of shelling out $300.00 for a riveting tool for the riveton a tour pack hardware can see spending all the money when i will just use it on 14 rivet
Old 08-26-2007, 12:44 AM
smknflms's Avatar
smknflms
smknflms is offline
Default RE: rivet tool
..borrow one.
Later
Old 08-26-2007, 07:51 AM
choochoo's Avatar
choochoo
choochoo is offline
I would suggest stainless steel screws instead of the rivets with lock nuts
Old 08-26-2007, 07:59 AM
electaRICK's Avatar
electaRICK
electaRICK is offline
what is it your trying to accomplish??????
Old 08-26-2007, 08:06 AM
bagga's Avatar
bagga
bagga is offline
ORIGINAL: rustyhd1948
when i had to replace the latches on my tourpac i had the dealer do it. it only takes a few minutes to do. buying the tool isn't worth it. thats the only thing i have had the dealer do in almost 20 years to my bike.
Old 08-26-2007, 10:24 AM
Retired_Ted's Avatar
Retired_Ted
Retired_Ted is offline
Dealer should be able to do it in 1/2 an hour.
Old 08-26-2007, 10:51 AM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
I had the dealer do mine, its not worth buying the tool.
Old 08-26-2007, 11:03 AM
snohomish's Avatar
snohomish
snohomish is offline
I've got a friend who has the required rivet pliers. We've replaced my hinges twice. Took all of 10 minutes each time. Cost me a couple of beers to borrow his pliers. I wouldn't have used those rivets if he had not had the pliers. Either let the dealer do it for you or replace the rivets with some bolts like previously suggested. Definitely not worth buying the tool for this alone.
Old 08-26-2007, 12:36 PM
screws4156's Avatar
screws4156
screws4156 is offline
Try "Harbor Fright Tool" A rivet puller will cost about $30.00 if that. The trick is find someone that knows how to use them.
Old 08-26-2007, 01:11 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
stainless \ chrome nuts - washer - bolts....
Quick Reply: rivet tool
