Notices
rivet tool
Old 08-26-2007, 02:57 PM
HilllBillly's Avatar
HilllBillly
HilllBillly is offline
Default RE: rivet tool
How much did the dealer charge you guys to put the tourpack hinges back on?
Old 08-26-2007, 03:19 PM
onephsyco1's Avatar
onephsyco1
onephsyco1 is offline
I replaced the latch myself , Just 2 screws.
But I had the dealer pop the rivets in the other end .
Cost me under $15.00 . I even gave the guy A few dollar tip ! That was on the 92 ultra I just traded in .
Jack
Old 08-26-2007, 07:56 PM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
It was wrapped into the price of painting the tour pak, not sure what they charge just to do the rivets, but it shouldn't be much.
Old 08-26-2007, 08:04 PM
thall's Avatar
thall
thall is offline
Take it to the dealer should't cost nearly as much as that tool
Old 08-26-2007, 08:20 PM
tlb's Avatar
tlb
tlb is offline
any bodyshop should be able to help you out. I have two pairs one really good rivet tool and one cheap. taking your time buying the proper rivet its really easy. the cheap set works as good as the expensive one. however, i dont really ever use either i am sure the cheap ones would break after awhile. but you should get at least 100 uses out of them. autozone may have ones you can barrow or home depot may rent them.
rrcap2001
01-15-2013 05:45 PM
booch
03-01-2012 09:15 PM
xwhyz1959
02-12-2011 08:04 PM
rider
11-05-2007 12:49 PM
risgdude
10-26-2007 02:44 PM
Quick Reply: rivet tool
