Cuts out
Old 08-25-2007 | 01:14 PM
tonyhdflht's Avatar
tonyhdflht
1st Gear
Default Cuts out
my problem is when my bike goes around 4 mile it cuts out like it ran out of gas,after letting it sit for 10 minutes it starts right up again . I've brought it to two mechanics the first one pulled the carb ,cleaned the gas filter changed the plugs and it kept happening. The second one changed th plug wires and solenoid and it still keeps happening. Anyone experincing this.
Old 08-25-2007 | 01:42 PM
choochoo's Avatar
choochoo
Default RE: Cuts out
year make and model would be helpful!
You need a new mech. He doesn't have a clue, and is just throwing parts
at it hoping to fix it. (plug wires can be checked with ohm meter)
Next time it does it, check and see if there is spark at the plug.
Carry a spare plug with you (best get one at parts store that has the grounding clamp mounted on it).
Pull one plug wire connect it to this plug and ground it to the engine.
Crank engine over. No spark it is electrical and now back track the cause.
You already have new wires so suspect the coil or control module or the crank / cam sensor if you have electronic. If points; the points and condenser.
If you have spark then most likely is fuel related.
Already rebuilt the carb (hopefully right). Pull the petcock fitting out of tank and inspect the screen and petcock for fuel flow . and the fuel line.
they deteriorate on the inside and can cause problems.
Old 08-25-2007 | 01:49 PM
RED E GLIDE's Avatar
RED E GLIDE
I had a bike that used to do that (not a Harley) and turned out to be
the vent in the gas cap. Try riding with your gas cap loose (if your tank
is not full) and you will be able to ride or it will still stall. If it doesnt still
stall your vent is the cause.
Old 08-25-2007 | 02:21 PM
98glider's Avatar
98glider
Try the coil See if the conn. are good
ToddFXDL
10-16-2016 12:48 PM
svarnster
07-26-2016 06:18 PM
bilsd1818
09-04-2009 05:15 AM
Razorback Rob
12-31-2008 10:19 AM
MoparScott
03-18-2008 06:11 PM
