Air compressor
Air compressor
I used to have a 2005 BMW K1200LT and will be buying an 08 RG. On the BMW, I had installed a Thomas 115 air compressor under the top tour pack and had a quick disconnect for the air line. I worked great!!! I don't know if there is enough room on the H-D's to do the same but if so, it is a good way to have a compressor that works and is out of the way. There are different models that put out more air, if needed.I tried to attach a photo ofa unit but the file was too large.I bought mine on Ebay. Just food for thought.
RE: Air compressor
This is another way to inflate your tires on the road.
http://www.stopngo.com/products/inflation/PQE1.asp
RE: Air compressor
I bought a 10 buck Walmart one and took the compressor out of the housing. I have a cig lighter socket that I plug in my heated gear harness. Those two with a plug kit fits nicely in a zippered bag........I used the kit earlier today while on a poker run. A guy picked up a a nail and had a sudden flat. We had him back on the road in less than 10 minutes.
[IMG]local://upfiles/17633/99FB1B5B0B68407B9F1DA84C260D4DBD.jpg[/IMG]
If I had a fairing bike, I would rig it up under the fairing. Check out eGlide Goodies. They have a kit that they have cobbled together withreadily availableparts for mounting a compressor under the fairing....You can make your own for far less than their 200 buck price.
http://www.eglidegoodies.com/id163.html
RE: Air compressor
I just bought a Slime compressor kit which includesa bottle of slime with the compressorfrom Walmart for $20. Fits nicely in the saddle bag without taking much room. It comes with a cig. lighter power cord and I purchased a female auxillarypower source which Walmart sells. Installed a terminal on the positive wire end and used the furnished round female plug for the negative side of the auxillary power cable from the battery. Along with a seperatetire plug kit, the compressor works great and now I don't have to worry about being stranded.
RE: Air compressor
ORIGINAL: Hogwallop
