Differences between the 2005 and 2006 Road Glide
Old 08-25-2007 | 03:33 AM
PapaTravis's Avatar
PapaTravis
Default RE: Differences between the 2005 and 2006 Road Glide
ORIGINAL: Harleypingman
The '05 had a one year only valve seal change that didn't work and HD ended up paying for replacements--if you want the '05 check to see if the dealer mod was done or not. The '06 has better flowing heads also.
Also, a new '07 leftover RG would probably be available for about $16,500 plus sales tax.
I have a '05 rk custom. I haven't had this issue. And hopefully wont. I bought mine 15 months ago with 770 miles on it. Not bad for a (at the time) one year old bike. I paid $16.5 for it, and I feel fine with the price I paid. It may have been a bit high, but when I saw it, I knew it was the one, and the price was not going to stop me from getting it. If you are looking at the '05, and are worried about the price being $16.5,I would say keep looking. Obviously that is not your bike. When you find 'your' bike, you will know and will have no problem paying the price for it, IMHO.
Old 08-25-2007 | 03:40 AM
atexn4christ's Avatar
atexn4christ
I didn't think they would finance me but they did a little more $$ a month than I was looking to spend. I got my 06 with 3,000 miles for 18,something first ofAug. last year. If that helps. But if the bike is what you want GET IT.
ORIGINAL: BigJess510
Maybe if I can get the Finacing I will go with a 2008 Dark Blue Pearl
Old 09-07-2007 | 05:13 PM
BigJess510's Avatar
BigJess510
Well Gentleman, I couldn't get the financing. I need a Co-signer and I don't have one so the wait continues.
Old 09-07-2007 | 05:34 PM
kruzin's Avatar
kruzin
The 06 also has the easy pull clutch
Old 09-07-2007 | 09:19 PM
Rininhoj's Avatar
Rininhoj
'06 also had the first 50 amp charging system. Up from 40 amp I believe.
Rini
Old 09-07-2007 | 10:15 PM
PhilM's Avatar
PhilM
06 has a 46mm TB vs 44mm on 02 ~ 05.
06 "esay pull" clutch has a soft spring that is VERY easy to make slip when you add much power.
05 has 4.3gm/sec injectors, 06 has 3.9 - even the 25degree replacements
8degree injectors on 06's were often problematic
06's ran HOT off showroom floor, 05's did not
PCIII has delayed start issues on 06's, not on 05's
Wiring harness changed in 06 to the channel that runs under the tank
Old 09-08-2007 | 08:58 AM
HogBack's Avatar
HogBack
PhilM... thanks for the information.... has the 46 mm TB been a plus or was the 44mm a better TB?
Thanks,
Old 09-11-2007 | 12:23 PM
DeathWind's Avatar
DeathWind
Most differences are mentioned above, but here area few other small differences for the '06s:
Dot 4 brake fluid
New Primary and Tranny oil for 10K service intervals.
TSSM Updated
Redesigned ball and ramp clutch-release mechanism from 21 degrees to 18 degrees
Reduced spring pressure on clutch diaphragm springresulting in approximately 24% reduction in clutch lever effort
New low friction clutch cable
Redesigned Cylinder Heads
• New intake and exhaust ports
Redesigned valve seals
TOURING MODEL SPECIFICS:
New Reflector-Optics Auxiliary Lights
Heat management program
New conventional style front forks (Electra and Road Glide)
• Both forks are now conventional style with a new triple-circuit damping mechanism
trampsinger
Motorcycles For Sale
05-10-2014 09:48 AM
06roadglide
12-01-2011 11:36 AM
hdegc
09-07-2010 03:03 PM
GRUNT77
11-25-2007 05:28 PM
ponesma
07-11-2006 06:17 PM
Quick Reply: Differences between the 2005 and 2006 Road Glide
