My gear indicator keep disappearing
Old 07-04-2023 | 03:11 PM
Burbur2's Avatar
Burbur2
Default My gear indicator keep disappearing
Hi All
Recently I noticed my gear indicator keep dissipating sometimes. When it happen no cruise control is also available. Any chance this can be related to sticky neutral switch or I should expect something more serious. Today it happened for the first time and make me worry as not having gear indicator sucks but it is not the end of the world while not having cruise control would be no fun.
Any guidance would be appreciated.
Old 07-04-2023 | 03:35 PM
Dseago1969's Avatar
Dseago1969
They read gear based on rpm and speed so it’s computed. If the clutch is pulled in it is missing part of the equation that it needs.
Old 07-04-2023 | 04:52 PM
Y2K's Avatar
Y2K
What bike and year and how many miles on it? Might help those in the know.
If it's still under warranty call the dealer.
Can't say I've even heard of this issue but probably someone in here has,good luck.
Old 07-04-2023 | 05:40 PM
Burbur2's Avatar
Burbur2
oops sorry 2022 Road King special 5k miles
Old 07-04-2023 | 05:41 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Check your Vehicle Speed Sensor (VSS).
Number 14 in the diagram below. It might be dirty or the connection not tight.
Chasingdrakes (07-05-2023)
Old 07-04-2023 | 06:07 PM
leftyjm's Avatar
leftyjm
Could be a sign your left hand switch pack is having issues
Oko (07-04-2023)
Old 07-04-2023 | 06:09 PM
cobra23's Avatar
cobra23
should be under warranty
The following 2 users liked this post by cobra23:
.john (07-04-2023), Y2K (07-04-2023)
Old 07-04-2023 | 06:34 PM
Y2K's Avatar
Y2K
Well a '22 should should still be under warranty,I would think it's probably a simple fix at a dealer.
The following 2 users liked this post by Y2K:
dasmotorrad (07-05-2023), OkieBill (07-04-2023)
Old 07-04-2023 | 08:43 PM
Burbur2's Avatar
Burbur2
Thank you guys and yes I rode this bike pretty hard in last few days as I am on the trip. Glad to see it is somehow easy fix in case this will keep happening. I will keep monitoring. Appreciate the advise. Looking into the diagram should I check tightness of screw #3? In case this thing is dirty how I can clean it up.
I feel this is rather not switch at the handlebar but I plan to lubricate it a bit after ai get home just in case.
Yes bike is still under warranty but local dealers sucks big time so if this is something I can correct I will rather do it myself rather than give it to these butchers as they cant ever fix anything correctly first time.
Old 07-04-2023 | 10:06 PM
skratch's Avatar
skratch
you're on a trip, so perfect time to stop at a different dealer and have them take a peek. who knows, they may have the part on hand and can fix it right away. i know if i were on a roadtrip, i would want to have functioning cruise control.
The following 5 users liked this post by skratch:
dasmotorrad (07-05-2023), hattitude (07-05-2023), Kenelz (07-05-2023), snowchopper (07-05-2023), Y2K (07-05-2023)
Quick Reply: My gear indicator keep disappearing
