HELP HOW TO ADJUST FINAL BELT DRIVE!
Old 08-27-2007 | 08:15 AM
DelawareDon's Avatar
DelawareDon
Default RE: HELP HOW TO ADJUST FINAL BELT DRIVE!
TJRKC....I tried to buy this tool at a couple of HD dealers. They would not sell it to me, indicating it was a HD shop tool which was not available to the general public. The tool you are looking for is a Rear Axle 36mm Nut Ratchet Wrench. Kaster Hand Tools makes it. It is available at ToolDiscounter.com (part #9636) for a cost of $39.55.
Old 08-27-2007 | 08:21 AM
TJRKC's Avatar
TJRKC
Thanks much, Delaware--really appreciate the lead...I'm being told the same thing by the dealer.
Old 08-27-2007 | 08:29 AM
smknflms's Avatar
smknflms
Here's the link: Rear Axle 36mm Nut Ratchet Wrench-Kaster Hand Tools
http://www.tooldiscounter.com/ItemDi...lookup=KAS9636
Later
Old 08-27-2007 | 09:35 AM
RDM's Avatar
RDM
I bought the ratcheting wrench from tooldiscounter to useon the nut side and I also bought one these http://pitposse.stores.yahoo.net/po36reaxnutw.html to use on the other side. The one from pit posse is about $20. I used them when I installed my IDS and they worked well.
Old 08-27-2007 | 11:19 AM
0204665J's Avatar
0204665J
Does anyone knnow where you can buy a belt deflection gauge as well. I had the same problem and cannot find the tools.
Old 08-27-2007 | 11:26 AM
RDM's Avatar
RDM
I bought mine from the dealer - 40006-85
Old 08-27-2007 | 02:50 PM
DelawareDon
HD dealers won't see you the wrench, but interestingly enough, they'll be glad to sell you the deflection guage.
Old 08-27-2007 | 06:07 PM
Pinon Hills Billy's Avatar
Pinon Hills Billy
http://chicagoharley.com/shop/advanc...p;x=31&y=7
Old 08-27-2007 | 06:08 PM
iclick's Avatar
iclick
ORIGINAL: TJRKC
You probably don't need anything other than a 36mm socket and a crescent wrench on your FLHRS, same with FLHX. The reason is that the 12" suspension doesn't stop low enough to cause any conflict with the muffler. OTOH, those with the 13" shocks (every other model) will likely need the tool. I have 12½ Progressive shocks on my FLHX and the socket just barely fits when the bike is on the kickstand, where the suspension is not bottomed out. It does not fit well on the lift, where the suspension bottoms out completely. I checked belt tension at 1000 miles on my SG with stock shocks at the time, and it was not a problem with the socket, a 1/2"-drive ratchet, and an extension.
Just break the nut with the socket, then loosen or remove it (e.g. wheel removal) with a large crescent wrench. BTW, for those of you looking for a cheap 36mm socket, I found this at Sears. For $9 you can't go wrong.
http://www.sears.com/shc/s/p_10153_1...rd=36mm+socket
Old 08-27-2007 | 07:36 PM
tomracer69's Avatar
tomracer69
just did mine on my 07 rkc ,. i just took off the right side muffler(15 min off/ 15 install) . theni loosen the left side . whole job took me under an hr .used 36 mm sockets on both side . the job was very ez to do . tommy
Quick Reply: HELP HOW TO ADJUST FINAL BELT DRIVE!
