Notices
Whip Antenna Hold Down Clips
Old 08-23-2007, 04:12 AM
Blacklion213's Avatar
Blacklion213
Blacklion213 is offline
Default Whip Antenna Hold Down Clips
Does anyone know where I can get the clips that slip on the passenger grab bar so I can hold down my whip antennas while parked in my low ceiling garage? Thank you.
Old 08-23-2007, 05:18 AM
FLHDRIVER's Avatar
FLHDRIVER
FLHDRIVER is offline
Default RE: Whip Antenna Hold Down Clips
Looks like I'm the answer guy this morning I changed over to J & M shorty antennas. The stock ones were a PITA in my garage also. The shortys, while a little pricy work better than stock and look good to boot.
Old 08-23-2007, 06:57 AM
FLHT's Avatar
FLHT
FLHT is offline
I replaced mine with one from e-glide goodies.
Old 08-23-2007, 07:06 AM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
Try Radio Shack.
Old 08-23-2007, 07:48 AM
Qball's Avatar
Qball
Qball is offline
I bought a shorty from e-glide goodies for the tour pack. I also cut 12" off my stock antenna without any adverse effects.
Old 08-23-2007, 07:53 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
It is not needed to do anything. Just hook the tip of the ant. by the chrome lock bar on your saddle bag toward the engine . There is a small slot and the tip fits perfect to hold the ant. down. I seen on the new hd's on the show room. Been doing it ever since.
Old 08-23-2007, 12:02 PM
serverpimp's Avatar
serverpimp
serverpimp is offline
Just figure out how much you need to clip off the bottom to clear the lowest pointand save some money. I removed 4" from both of my antennas and 'Wa-La' problem solved.
Old 08-23-2007, 12:28 PM
luckystars5's Avatar
luckystars5
luckystars5 is offline
Here you go:
http://www.customcruisers.us/
Old 08-23-2007, 03:19 PM
larry5h's Avatar
larry5h
larry5h is offline
Or you can put the ball end in the tour pak latches.
Old 08-23-2007, 06:51 PM
sully78's Avatar
sully78
sully78 is offline
I just took my antenna off and cut off a certain lenght from the bottom and put it back on, no problems with reception at all. Plus its free.
Quick Reply: Whip Antenna Hold Down Clips
