TFI on '08?
Old 08-22-2007 | 08:50 PM
Ultra_Bob's Avatar
Ultra_Bob
Default TFI on '08?
Has anyone installed a TFI fuel management unit on an '08?
Old 08-22-2007 | 10:33 PM
drdiesel1's Avatar
drdiesel1
Default RE: TFI on '08?
What`s a TFI unit and who makes it. Sorry for the question, but I`m not familiar with the name. Thanks
Old 08-23-2007 | 12:17 AM
Ultra_Bob's Avatar
Ultra_Bob
http://www.dobeckperformance.com/
Works on an '07 .. I wonder if it will work on an '08?
One wireto the battery ground, and connect harness to the injectors. ECM doesn't know it's there.
Easy setup .. Comes with a couple 330 ohm plugs... Got mine under the seat of both my Electra Glides.
Old 08-23-2007 | 05:49 AM
harleyflo's Avatar
harleyflo
what do you mean comes with 330 ohm plugs-whats that for.
Old 08-23-2007 | 10:52 AM
Ultra_Bob's Avatar
Ultra_Bob
Unplug the O2 sensor connectors.. plug in the 330 ohm resistors... No more closed loop.
Old 08-23-2007 | 11:15 AM
gunrunner's Avatar
gunrunner
I think the injectors were changed somewhat on the 08 to go with the new 50mm throtle body, but they may still have the same connection.
Old 08-23-2007 | 11:25 AM
Ultra_Bob's Avatar
Ultra_Bob
ORIGINAL: gunrunner
Thanks for that info..
Old 08-23-2007 | 11:33 AM
dawg's Avatar
dawg
I doubt if anyone has done any fuel management to the 08's yet, HD hasn't even shipped out the SERTS or offered a download yet. Mid September and you will see the setups being done.
Old 08-23-2007 | 02:36 PM
harleyflo's Avatar
harleyflo
so this means you dont need your o2 sensors in your header pipes --right
Old 08-23-2007 | 07:54 PM
Ultra_Bob's Avatar
Ultra_Bob
ORIGINAL: harleyflo
I'm not usingmy sensorsand the engine runs much cooler.. and has much more pep.
This by all means isn't the right fix, but it gets me by for now.
I'm waiting for another solution to the heat issue. I read the pamplet inserted into the summer edition
of the Enthusiast. Very thought-fully written. The person that wrote it .. said big bores make more heat.
I have been around large bore v-twin japanese bikes. They seem to run cooler then my TC96? I wonder
what AF ratio they are running? Maybe it's all in the timing?
djcustom1
Softail Pictures
01-14-2010 07:30 PM
norskehd
01-15-2008 06:47 AM
silvrbill
08-17-2007 08:37 AM
huffhuff
07-11-2007 11:47 AM
Isshinryu
07-20-2006 05:47 PM
Quick Reply: TFI on '08?
