To lower or NOT to lower?
RE: To lower or NOT to lower?
I lowered the rear of my EGC 1 1/2". I used a set of relocation brackets to get the job done. Cost $83 and took 20 minutes to install. It work to get me flat footedand rides the same but I had to pump up the air in the shocks when riding two up to keep from bottoming out on very hard bumps. But I can touch a lot better now
If you just want to do 1 - Get you SEAT LOWERED Mean City Cycle... Heard nothing but good things about there work from the users here & they're a vendor....
I have tried lowering blocks and riding 2-up loaded even with the rear shocks over filled (and when you need to do this you lose the cush for the tush)... Still bottomed out at times....
If you use lowering shocks... you'll have shorter shock travel there by giving up some of the comfort ride...
I would try the seat mod first then if needed go from there...
I would first try a odd quality seat that will get you lower in combination with good riding boots with a thick sole. If you need more, then I would get a shorter pair of good qualtiy shock, such as progressive. I have 11.5" Progressive 440's on my RK and love them.
I have the stock 12" air shocks on my RK Custom. I lowered the front an inch with HD fork springs. I also had my seat shaved down some and narrowed. All helped. Ran into a guy today riding an Ultra that was shorter than me. His secret ? He had his boot soles raised at least 2 inches at a local shop. I couldn't tell till he showed them to me.
