Harley Center Stand
I have the EZ-up on my 05 eglide-Takes about 10 minutes to install-Works great-Easy to get up or down after
a little practice. I originally got it because of my limited garage space but find I use it all the time now when parking on level places. Also you can safely drive off it.-Very well made-
ORIGINAL: stuntmn
Try this site........ http://wheeldock.com/ I have one and it's great...real easy to get it upon stand.
Too bad they don't offer a chrome model.
I could use a little help regarding the display stand, 99002-97A. I bought one from a friend that went to an oil cooler.
All I have is the stand with the swivel mount, no extra hardware or install instructions. He had a mechanic remove it and hetold me thatno other hardware or brackets are needed, everthings on the bike. There are 4 brackets on the mount, 2 flat and 2 angled up at about 25 degrees. I do not see anything on the bike that corresponds with these, it's a 2007 Ultra.
I am afraid that the mechanic left something on the other bike. It would be very helpful if someone could send me a scan of the install instructions so I get started with this.
If you could tell me if there are more parts needed,that would be helpful, maybe I can still get them before they disapear.
Thanks.
Thanks.
ORIGINAL: Nonferrous
Thanks.
Thanks.
I have the HD display stand on my '08 EGClassic, works like a charm and takes about 30minutes to install.
BTW I just put it upon theParts for Sale forumand yes, it is the chromed, adjustable one.
Not my intention to hijack your thread and with all due respect, if anyone is interested it's here https://www.hdforums.com/m_2849239/tm.htm
Thanks
Thanks
I'll try to post the third attachment from the ad in the classified. If it doesn't work go check it out and you'll see what I'm talking about.
It's not workingworking.
You'll have to remove the regulator, I'm pretty sure the bolts are too short, so you'll have to knock them out and instll longer ones.
Then you'll need some spacers and longer bolts were itattaches on to the bolt that holds the bottom of the engine guard.
