Now that it's a cable clutch is there still enough cable for my 14" bars?
I thought 12” bars were basically the cutoff or height limit, that would “not” need replacement cables or extensions, only requiring snipping of several wire-ties holding the existing cabling connections under the fairing and a little maneuvering, to gain the slack needed……it would probably be best to call or email outfits that offer and install hundreds of handlebar replacements - like KST Kustoms or Hill Country Cycles
I have same bike with 14 inch factory 47 bars. You can do it with stock clutch. However I recommend getting the fat baggers 4 in c h extension. Then you don't have to reroute the cable
