FLHRC Road King 2002 - Oil Pressure Gauge
Hi Guys,
as I have received already a lot of great support here, decided to ask for more
I have went through cam tensioners replacement on November last year.
Basically, except all the other stuff I have replaced, there is a new oil pump.
I would like to monitor my job, and double check if the pressure given is proper.
I have found the gauge that can be installed on the rocker box.
DO you use such stuff ? Is it comfortable to ride ? does it disturb during the ride ?
maybe, as more experienced you have the better places for this stuff.
All support will be highly appreciated.
Basically that is the one I am looking at : https://malyhd.pl/bagnety-wskazniki-...ju-li-025.html
Thank you in advance.
The following 2 users liked this post by jake24lt:
Fritz Franz (02-27-2023),
IronAss (02-24-2023)
As @jake24lt said, replace the plastic hose.
Other wise, that should work fine depending on where your right knee is when you are riding which is different for everyone base on your height, seat and other factors.
I do not have any in my bike, so it shall fit nice and easy.
RK_Classic (02-24-2023)
Ok Comming back to the topic.
I have ordered the gauge and it has arrived.
that is ok.
I have my doubts as mentioned previously about the connecting pipe. Basically it is not about the pipe itself, it is made of nylon and shall be ok with temperature and pressure.
my problem is that I do not trust into the way the fitting for this pipe is made.
Pressure goes up to 40 PSI let us say - approx 3 bar.
and these are some kind of small nuts with bevel in it. I am not quite sure if this will be tight enough.
some photos to show you the mounting of the pipe
that is ok.
