Sirius Radio
Sirius Radio
Need a little help here guys, am trying to hook up my after market radio to my ultra, using the CD port on the bike radio. Problem is I am getting engine noise though the radio. The noise is there even if I turn the power off at the satellite radio however it will go away it I unhook the power cord from the satellite radio. This tells me the noise is coming through the power cord- am getting the power from the cigarette lighter. Not sure what to try next – any ideas?
RE: Sirius Radio
I just traded a Low Rider for a Ultra Classic 2 weeks ago. One of the first things I did was install my Sirius radio on the new bike. Wired a fused wire to an extra wire around the headlight. No noise at all. Works great. On/off with key. Has power with switch in ign or accy position.
I'm also in Tulsa if you want to have a look sometime.
JC
JC
RE: Sirius Radio
It sounds like you are trying to hook up Sirius radio, if so, make sure the FM Transmitter is turned off on the Sirius unit. Go to Menu and scroll through to shut off the FM transmitter..... don't ask me how I know.... also turn up the volume on the Sirius unit all the way, then control the volume with the stock radio
RE: Sirius Radio
If you are hooking up a newer style Sirius receiver, the Power Cord has to be 5 volts. I got a cig lighter from local dealer that plugs into the auxillery plug under the seat. Works great. If you need a mount, try this http://www.tss-radio.com/professiona...k1-p-4430.html
RE: Sirius Radio
Check out cyclegadgets.com's website. they have a kit or individual connections to hook up you SAT radio.I originally ordered the install kit from J & M (they make a kit also), but it didn't fit my receiver so they gave me a refund and I call cyclegadgets. You can get inline filters for the power cords from both vendors i believe, it solved my problem.
My only gripe with the MOCO, is that they don't give you a second/seperate AUX port for your GPS (turn by turn directions) audio, like Honda and BMW do. If we listen to SAT radio, you need an earpiece for the GPS, a real PITA.
RE: Sirius Radio
JC Are you using the FM transmiter on the sat radio or are you using a cable? I am trying to use a cable and am having a problem doing that. If I use the FM it works just fine but as I am touring I keep hitting places where I need to change the station as I am hitting a local station.
RE: Sirius Radio
I use a cable from Audio out on the sat radio to Aux plug on console. Radio Shack has a 1' cable with 3.5mm male on both ends. I'm using the Streamer GT sat radio. I bought it when I had my other bike because I could hook earphones direct to the radio.
Hope this helps.
Jerry
Hope this helps.
Jerry
Orange Smoothie
07-23-2012 10:34 PM
