21" front wheel & ST front fender?
Old 01-25-2023 | 11:41 AM
Big Twi$t's Avatar
Big Twi$t
Default 21" front wheel & ST front fender?
Quick question.. I have a stock ST front fender on my non ST Road Glide. I will be replacing my wheels and the wheels I want, the front only comes in 21"..
Will the 21" tuck up under the ST front fender? Has anyone tried? I no longer have my stock front fender, and the reason I ask is the ST front fender definitely looks like it hugs the wheel more. ??
Any help is appreciated.
Old 01-25-2023 | 12:31 PM
Taxgod4u's Avatar
Taxgod4u
Can you fit a 1" piece of something between your current wheel and fender?
Old 01-25-2023 | 12:38 PM
RKZen's Avatar
RKZen
Gonna be more like 1 1/2" total clearance . I have a 21" wheel on my King and the common tire size for the 21" wheel is 120x70/21, so the diameter diff is about 2 1/2". He'll need the extra 1/4" for tire expansion when hot and in case an errand rock gets in there.
Old 01-25-2023 | 01:47 PM
Big Twi$t's Avatar
Big Twi$t
Front wheel and fender not currently on bike.. going by memory. Best guess it will not work, was checking if anyone had experience with it working. Thanks.
Old 01-25-2023 | 02:35 PM
RKZen's Avatar
RKZen
So what tire size you currently have? Your forks stock? Your sig says you have a built 2020 RGS, so I guess all bets are off. As I understand, both the 2022 RG ST and 2020 RGS have the same stock front tire size, thus the comparison above.
Old 01-25-2023 | 03:18 PM
Big Twi$t's Avatar
Big Twi$t
Bike is going through some more changes.. currently up on lift.
Yes, stock size front wheel 19”.. front wheel & fender off and I don’t have the wheel right now or I’d have it figured out.
Old 01-25-2023 | 03:34 PM
Taxgod4u's Avatar
Taxgod4u
They sell fender risers that will probably become invisble next to your new chiny wheel. Might be worth a try before spending on a new fender and paint or to mock up for the next fender..
widegliderider
Shovelhead
01-09-2013 09:08 AM
Wardo8379
07-21-2012 07:51 AM
sleepersti
12-30-2011 05:32 AM
murlsquirl
11-13-2011 06:30 PM
BigFokker
11-16-2008 07:25 PM
Quick Reply: 21" front wheel & ST front fender?
