Wheel bearing tool
Old 02-18-2024, 02:54 PM
timbo141's Avatar
timbo141
timbo141 is offline
George`s Garage sells the correct tool...He may give you a break since the first tools he made were incorrect.
I just saw it and posted it, thanks for the info.
I will see that they will do.
Dan89FLSTC (02-18-2024)
  #42
Old 02-18-2024, 04:28 PM
vizcarmb's Avatar
vizcarmb
vizcarmb is offline
Not worth it. Take the wheel off and pay someone.
i contemplated buying a tool and realize it’s just not worth doing for me personally.
Get the Jim’s tool
  #43
Old 02-18-2024, 04:53 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,312 Likes on 1,860 Posts
George will swap out yours for new ones (as per george). Just contact him.
Originally Posted by timbo141
Well my George's garage puller/installer kit purchased in 2013 is also machined incorrectly, bummer.
I will now flip it as I get close to the spacer.
Does anyone just sell the correct 25mm install tool?
I see Jim's has one but it is the same one that is in my George's set.
The following 4 users liked this post by multihdrdr:
Dan89FLSTC (02-18-2024), LQQK_OUT (02-19-2024), timbo141 (02-19-2024), Uncle Larry (02-22-2024)
  #44
Old 02-18-2024, 08:29 PM
btsom's Avatar
btsom
btsom is offline
Any of these kits have an installer that pushes the bearing in far enough but not too far? If I remember correctly, the shop manual shows a driver with a shoulder on it that keeps the bearing from going in too far.
  #45
Old 02-18-2024, 08:39 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by btsom
... pushes the bearing in far enough but not too far?
That is accomplished by the combination of the bottom of the bearing bore on one side, the center spacer sleeve to stop bearing on the other, and either a good installation tool that pushes on the outer and inner race simultaneously or know the "work around" when using a not-so-good tool.
EDIT: forgot to address the factory tool "driver". The HD Kent -Moore tool has NO shoulders/ridges on it's "driver". Completely flat across the surface. George's achieves effectively the same thing with the 2 raised ridges.
Rollbar (02-19-2024)
  #46
Old 02-19-2024, 07:02 AM
702's Avatar
702
702 is offline
Received 5,797 Likes on 2,371 Posts
https://www.hdforums.com/forum/dyna-...l#post20968855
I have a wheel bearing tool that was like the pit posy, ate a couple wheel bearings in about 4000 miles. Ended up reversing dies for the final press. That corrected the bearing life.
While the stock bearing with C3 clearance has about 0.005" axial play, the bearing dies with a outside ridge that high between the inside and outside stress the bearing axially and kill it. The installer set I have was 0.025" I got tired of turning the dies around and machined them flat. No issues since.
Circling back a year later to thank you for the tip and info. A little lathe time, and all fixed up ---
The following 4 users liked this post by 702:
BrandonSmith (02-19-2024), hattitude (02-19-2024), Max Headflow (02-19-2024), Rollbar (02-19-2024)
  #47
Old 02-19-2024, 06:48 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,652 Likes on 1,127 Posts
George's has the 25mm set by itself but is currently out of stock.
https://www.georges-garage.com/produ...r-shaft-pilot/
Get in touch with George's Garage.
He swapped out my old version.
Now that is what I call "First Class" customer service!!!
  #48
Old 02-20-2024, 08:55 AM
hattitude's Avatar
hattitude
hattitude is offline
Received 8,199 Likes on 4,406 Posts
I called them once because I was having an issue with one of their tools.
The guy I talked with was very knowledgeable. We were on the phone for about 20 minutes, both with dial calipers in hand making measurements. He finally figured out what I was doing wrong (yep, operator error, go figure).
Excellent customer service...
The following 2 users liked this post by hattitude:
Max Headflow (02-20-2024), Uncle Larry (02-20-2024)
  #49
Old 02-20-2024, 10:53 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,623 Likes on 1,621 Posts
The reason i replace my own bearings is to make sure it's done correctly. I wouldn't let someone else do this even it was free.
I have already had the dealer fkup installation once when it was under warranty..
Mr-DD (02-20-2024)
  #50
Old 02-20-2024, 11:21 AM
Mr-DD's Avatar
Mr-DD
Mr-DD is offline
Default Wheel bearing tool
I too will be replacing front and rear wheel bearings on my 2020 RG Ltd during this current tire replacement. Will use bearings from the dealer or from All *****.
I need a good quality bearing puller. I really don’t want to purchase one and use it once then set on the shelf for years. I’m in search of someone that would be willing to let me rent / borrow their quality bearing puller. Goes without saying; shipping will be on me and I can send a deposit.
Thank you!
Quick Reply: Wheel bearing tool
