Battery recomendations
Old 08-19-2007 | 04:44 PM
bigheadted's Avatar
bigheadted
Default Battery recomendations
I have the stock battery in my 04 Road King that has performed perfectly so far and have started to consider replacement before it is needed to avoid hassles while on the road, other than the dealer what are some other places to get a good battery and / or good batteries you have used or are using ?
Old 08-19-2007 | 04:54 PM
voodoodrug's Avatar
voodoodrug
Default RE: Battery recomendations
exide is made locally here in pa. I beleive? at least they have a ware house full with skids to the ceiling of motorcycle batteries. Ive used them with great success but I may just stick with HD next time for only a few dollars more. piece of mind? better then most?
Old 08-19-2007 | 04:56 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Hate to say this but..... HARLEY does make a good battery
Old 08-19-2007 | 05:29 PM
Shovelhead Bob's Avatar
Shovelhead Bob
HD batteries are manufactured by East Penn Mfg., under the DEKA brand, and re-badged for HD use....
They are the best battery you could use, it is an AGM (Absorbed Glass Mat), Maint. free, perfect fit with the correct CCA's and Voltage requirements....
Old 08-19-2007 | 05:33 PM
st john's Avatar
st john
I agree, HD battery. My last one lasted over 4 years before it gave out.
Thats AZ heat for four years on a dresser.
Saint
Old 08-19-2007 | 06:28 PM
maineultraclassic's Avatar
maineultraclassic
This will be my next battery -
http://www.odysseybatteries.com/battery/pc925lmj.htm
PhilM just bought one, and I'm waiting for his review before I pick one up.
Steve
Old 08-19-2007 | 06:35 PM
DocHarley's Avatar
DocHarley
ORIGINAL: SoCal_Pappy
I've got to know.......
Why would you hate to say HD has a good battery?
Old 08-19-2007 | 08:54 PM
NICK56's Avatar
NICK56
ive had much better luck with sears die hard batteries...
Old 08-19-2007 | 09:18 PM
SteveO's Avatar
SteveO
You have to be very carefull with the battery dimensions and exact terminal locations of aftermarket batteries.
I went back to the HD battery after trying to modifyan aftermarket batterybattery to fit. The battery was 1/2" short and the terminals were also two low, made it very hard to hook up the battery with numerous acessory wires. My previous HD battery lasted over four years. The new HD battery was only $90 from HD and fits like a glove!!!
Steve
Old 08-19-2007 | 09:43 PM
bigdaddy405's Avatar
bigdaddy405
I had the same HD battery in my bike for 5 years no problems. I store my bikes in my other garage for winter across town so I pull the batteries & store them in my basement with a 2 amp charge once a month till spring. I finally bought a new one just in case.
