Brake problem
Old 10-18-2022 | 10:15 AM
LQQK_OUT's Avatar
LQQK_OUT
I just had a similar problem on my 2011 Ultra. I ended up replacing both front calipers at US$238 each (ouch). I'll rebuild my original calipers and now I'll have a backup set. My problem was that I didn't realize one is supposed to clean the calipers with soap and water before pushing the pistons back in.
DanHappy (10-18-2022)
Old 10-18-2022 | 11:32 AM
DanHappy's Avatar
DanHappy
Yes, the master cylinder cover was off, and i removed a little of the fluid so it didnt overfill.
DanHappy's Avatar
DanHappy
No codes. Thought the same thing. At first, i was thinking the ABS module took a dump.
Old 10-19-2022 | 08:24 AM
memphisharley's Avatar
memphisharley
Veteran: Marine Corp
have you ruled this out..if so how.
thanks
Old 10-19-2022 | 08:39 AM
Tired's Avatar
Tired
Just wanted to thank Dan for using the correct spelling of, "brake". Thank you!
DanHappy (10-21-2022)
Old 10-21-2022 | 11:39 AM
DanHappy's Avatar
DanHappy
thanks
I havent ruled out anything yet. Just have too much going on to get back to looking at it. Possibly this weekend unless my wife has other plans for me.
Old 10-25-2022 | 10:52 AM
btsom's Avatar
btsom
The most frequent ABS failure traps brake fluid between the master cylinder and the ABS unit resulting in a locked lever or pedal but no pressure to the caliper. Hydraulic lock from the master cylinder all the way to the caliper could a blocked equalization port in the MC or the master cylinder piston NOT retracting far enough to open the equalization port to relieve pressure. Did your brake lever have any free play before hitting the locked MC piston or did it seem to be normal movement to that point? With dirt on the caliper pistons, it is possible the first brake application pushed the caliper pistons hard against the brake pads and the pistons were then jammed and unable to retract when you released the lever. Since function seemed to return to normal once everything cooled off, why not remove the new pads and extend the pistons as described above and clean the pistons. As a personal technique, I lube the extended pistons, after they are clean, with a couple drops of DOT 5 brake fluid and cycle the pistons in and out until they move easily. DON'T put DOT 5 into the brake system, it is not compatible with DOT 4 or the ABS system. If using DOT 5 just to lube the pistons makes you uncomfortable, use DOT 4. Rebuilding calipers that can be made to work properly seems like a lot of extra work and money you may not need to spend. If you are prone to worry about a recurrence of the malfunction, then rebuilding will provide peace of mind.
My personal experience was somewhat similar to yours. After my first pad replacement, my gas mileage decreased considerably and I found the front brakes were dragging, but no hydraulic lock. After cleaning and lubing the caliper pistons, everything went back to normal. Each pad replacement was then done with the piston cleaning procedure and have had no further problems. I now have 108,000 miles on the bike.
Old 10-25-2022 | 12:47 PM
hardheaded's Avatar
hardheaded
I always clean the pistons with brake cleaner and an old tooth brush and then spray silicone spray on them before pushing them back in. Do this on autos too.
Old 10-25-2022 | 02:05 PM
tankthebiker's Avatar
tankthebiker
What year is the bike? My 2010 I bypassed the ABS and it solved all issues.
Old 10-25-2022 | 08:01 PM
commander47's Avatar
commander47
All,
I just went and replaced my front brake pads. The calipers were a bitch at first to compress on both sides, but i got them enough to get the new pads on.
If you had to force the piston in "just enough" to jam the pads in then you did not open the master cylinder. You need to open the caliber bleeder just a little and let some fluid out.
The calipers should retract pretty easily with a large clamp and a wood block. Put in the new pads, and bleed the brakes.
MotoArts
05-09-2019 07:15 PM
glswitzer
04-07-2015 03:15 PM
sledder69
07-03-2012 09:15 PM
bikemike03
05-03-2009 08:55 AM
Wilbur4s
Wheels/Tires
04-13-2009 09:26 PM
Quick Reply: Brake problem
