Ultra classic inner fairing alignment?
I don't see anything in the service manual about aligning the inner fairing so I'm asking for help here.
Looking at the inner fairing from the drivers seat the left side fairing mounted mirror is much closer to the handle bar than the right side mirror.
If I look along the ridge of the inner fairing at there closest point to the handle bars the left side is almost touching and the right side has a gap of maybe an inch. I would like to move the left side out to get the mirror farther away from my clutch lever and make it look more symmetrical with the right.
Is the adjustment possible? I have the outer fairing off now but cant see what needs to be adjusted.
Thanks,
[/align]
Thanks,
[/align]
RE: Ultra classic inner fairing alignment?
ORIGINAL: drdiesel1
The clutch lever perch sounds like itneeds to be rotated to match the brake lever.
Check your levers and make sure they are set the same first.
[IMG]local://upfiles/14445/3A5292C74EA94B4DB8A8EC235F203BAD.jpg[/IMG]
The only thing that holds the fairing to the bike is the four Torx head screws on the upper forks. There are two one either side.
About the only thing that could be done, is loosen the two on the left side and trying moving the bottom in and tighten. A small movement down there will translate into a lot more movement at the upper part near the bars. (The innerfairing "leg" should fit symetrically around the upper fork tube)
You will be moving the inner fairing and the inner fairing brakets when you loosen those screws.
ORIGINAL: SteelCityScooter
Thanks again... It would have kept me up all night.
