Added an external head breather
The following 4 users liked this post by Bingee:
Do any of you guys/gals ever use the head breather bolts instead of all the lines and a catch can. I got mine from TC brothers. They screw right in to the heads and have a mesh screen and a foam filter. Very neat and clean. I get a very light mist of oil from them if running the bike kinda hard but never a mess ever.
https://www.tcbroschoppers.com/
The following 4 users liked this post by Spook13:
The following 2 users liked this post by Bingee:
Bafflingbs (09-28-2022),
hattitude (09-28-2022)
I did the same , hardest part was drilling and tapping , instead of using standard hose clamps , I used compression clamps , really cleans things up . The only problem , is you have to have the correct tool to use them , I already had it from doing a lot of irrigation work . I only ran my hose out to atmosphere , not a lot of oil coming out , so not worth the catch can .
The following 5 users liked this post by Bafflingbs:
MyFavRk (10-14-2022),
OkieBill (10-12-2022),
PureHybrid (10-13-2022),
Spook13 (10-12-2022),
Tired (10-13-2022)
Bafflingbs (10-13-2022)
A word of caution from a lesson learned. I thought I would be able to get away with 1/8" ID tubing instead of the 1/4" most kits use. I ended up replacing my rocker box lower gaskets in short order. Not a horrible job, but now I have 1/4" ID lines after redrilling and retapping my air cleaner. There's too much pressure for a 1/8" line to effectively relieve.
Rollbar (10-16-2022)
