Brake line help needed
Old 09-15-2022, 05:39 PM
Burbur2's Avatar
Burbur2
Burbur2 is offline
Yeah they magically figured now stock cable is long enough 🙄 thank you guys anyway for willingness to help
Old 09-15-2022, 06:39 PM
Musician's Avatar
Musician
Musician is offline
I thought I could just replace the upper line on my 2008 FLHT, when I went to the 14 inch bars. Nope. Upper line, splitter block, both lower lanes. All one assembly. You may want to confirm yours can be separated before buying a line you maybe can't use.
Old 09-15-2022, 06:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,862 Likes on 2,554 Posts
I agree it's really odd that the dealer tech's haven't a clue how to do this. I would also be surprised they would install a non HD part and be liable for it. It's like taking your eggs to a cafe and asking them to cook them and then complain the eggs don't taste good. The HD line would be warranted but that $300 could buy a couple of loaves of bread, your call.
Old 09-15-2022, 07:08 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 4,242 Likes on 2,323 Posts
He has ABS. The diagram I posted above shows the line from the master cylinder to the ABS module is by itself and not part of the front brake line assembly.
Old 09-16-2022, 03:24 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,877 Likes on 1,272 Posts
That could very well be the case if you 08 does not have ABS.
Not all 08's had ABS
WP
Old 09-16-2022, 05:55 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
Same thing for me. 9 years later, the splitter block is all rusted but everything is working great
Old 09-16-2022, 06:34 PM
Burbur2's Avatar
Burbur2
Burbur2 is offline
Default Adjusting brake line - need help
I need to adjust this brake line slightly by rotating it a bit. Any chance I can slightly loose this screw and rotate the line without risk of unsealing the brake system?
Old 09-16-2022, 06:42 PM
NoRegerts's Avatar
NoRegerts
NoRegerts is offline
Received 8,954 Likes on 4,700 Posts
Yes, you can loosen it just a little and rotate it. I've done it countless times.
Old 09-16-2022, 06:44 PM
Calif Fat Bob's Avatar
Calif Fat Bob
Calif Fat Bob is offline
Received 1,848 Likes on 960 Posts
Yep did mine just last month. Just loosen it a little. Be careful not to let the wrench jump
Old 09-16-2022, 06:52 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
Keep just a little line pressure on and then adjust it. This will keep any air from entering the system.
Quick Reply: Brake line help needed
