how long till synthetic switch ??
Old 08-17-2007, 01:21 AM
glens's Avatar
glens
glens is offline
Default RE: how long till synthetic switch ??
I didn't do a 500. At the 1000 they put their syn in all three holes. At 5000 I put Mobil 1 in the crankcase.
Old 08-17-2007, 02:15 AM
chipishere's Avatar
chipishere
chipishere is offline
DU IT
Old 08-17-2007, 03:13 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
I did mine at 5k, but I don't think at the 1k will hurt anything. Heck, screaming eagles come with it from the factory.
Old 08-17-2007, 05:27 AM
Buzzard69's Avatar
Buzzard69
Buzzard69 is offline
NOW DO IT NOW
Old 08-17-2007, 07:12 AM
NCCopBikeRider's Avatar
NCCopBikeRider
NCCopBikeRider is offline
Ditto on the now
1000 miles is more than enough time for all of the moving parts to have "seated" themselves. Dino is great, if change often, while the bike is new to let all of the mating pieces get to knon each, other, then Syn for long life.
Ride Em Carry Em
Old 08-17-2007, 08:03 AM
creep1's Avatar
creep1
creep1 is offline
OK - now that the 1000 mile mark appears to be the general rule of thumb on here what combo do you guys think is better?
1. amsoil (20-50) in crankcase, mobil 1 (75-140) gear oil in tranny, hd syn 3 in primary.
OR
2. Mobil 1 (20-50) in crankcase, amsoil severe gear(75-140) in tranny, hd syn 3 in primary.
Old 08-17-2007, 08:07 AM
Lost1's Avatar
Lost1
Lost1 is offline
If you want to change to synthetic, do it any time you want. The engineinternals are "seated"before the engine leaves the factory, which explains why H-D, and many other manufacturers, ship their vehicles with synthetic oil from the factory.
Unfortunately, there are as many answers to this question as there are mechanics, and many base their opinion not on factbut on outdated myths of synthetic oil being "too slick." Personally, I'd be more inclined to believe the engine manufacturer or the oil manufacturer than anyone else, including your local mechanic or those in an internet forum.Harley-Davidson says syntheticoil is safeat any stage of engine life. (This ends the debate altogether, IMO.) Most oil companies (Mobil, Pennzoil, Valvoline, et.al.) also recognize there is a lot of incorrect information on this subject floating around and address the question in the FAQ section of their websites, and agree that you can put synthetic oilin an engineat any time.
I can also say that in over 25 years as a mechanic and engine builder I have yet to see a single problem or failure attributable to the use of any synthetic oil in any engine at any stage of its life...
Peppa1's Avatar
Peppa1
Peppa1 is offline
No reason to wait. It can only make things better.
Old 08-17-2007, 08:09 AM
tizone's Avatar
tizone
tizone is offline
Start wth hd Syn 3 in the garbage pail and then go from there. I can tell you that Redline Shockproof Heavy in the tranny makes it smooth like butter!
Lost1's Avatar
Lost1
Lost1 is offline
ORIGINAL: creep1
OR
Any good synthetic in the crankcase, any good gear oil or H-D Formula+ in the tranny, and Formula+ in the primary.
Quick Reply: how long till synthetic switch ??
