Front brake pads.
Front brake pads.
I have a 21 Street Glide Special with the RDRS. I
just checked my front pads, without removing
the caliper, and I see a good deal of the groves left on the set in the caliper on one side, but the set in the caliper on the other side are worn through and need to replaced. I'm planning on replacing both sets but is this a common occurrence or is there and underlying issue that needs to be addressed?
One side of the caliper is fixed, the other side is pressed out by the piston(s). It's normal to see one side wear more than the other some since only one side has the piston(s). The other side moves back a bit when the lever is released by the lubed pins. A great deal of wear on one side only can be attributed to many factors. Dirt, wear on the piston(s), dry caliper slide pins, sticky piston(s), are the most common.
A thorough inspection and cleaning are in store for you as well a pad replacement I would assume. Several videos and write ups on how to do that. As well as what's in the FSM.
The following 3 users liked this post by lp:
Thanks. I just found it odd that the two separate calipers on the front weren’t wearing evenly. I’m probably just overthinking it.
There was also an issue where my front master cylinder was empty one morning. It ended up being from the Fat Baggers eEz Install Kit that was used for the Apes I had put on when l bought the bike. There is a splitter for the brake line extension inside of the fairing with a bleeder valve. It had loosened and leaked inside the fairing.
Shame on me for not researching it first and paying the to run it the stock way. Live and learn.
Either the caliper has pistons on both sides of the rotor (most motorcycles), or the caliper slides on greased pins (many cars).
When a piston sticks in the caliper, or the caliper sticks on pins, uneven wear takes place. Braking effect is reduced too.
PaulG75 (08-27-2022)
It will never be perfectly symmetrical. But it should be fairly close.
PaulG75 (08-28-2022)
