99 Ultra Classic Injected Fuel Pump Wiring Question (FLHTCU-I FLHTCUI)
Hi folks, hoping I could get a quick bit of help here. I am working on a neighbor's '99 Injected Ultra Classic and I was wondering if someone could tell me if it is normal for the wire in the picture (yellow with green stripe) to be powered at all times, even if the key switch is off. Also, I would be very grateful if anyone could provide a wiring diagram for this bike, I've done my searching but haven't found anything online for one of these MM/Twin Cam Injected (99-01) bikes yet. Any help would be much appreciated!
Thanks!
David
Thanks!
David
Awesome, appreciate the help man. Are your pictures when you checked with Key Switch OFF or Key Switch ON (Looks like it is off in the pics, just double checking).
I believe I am going to have to go ahead and purchase the factory service manual for this bike to get to the bottom of this.
Also it looks like you have the same color bike as him...... dark green with gold emblems/pin stripe?
I did check voltage with the ignition off. The red (positive) tester lead is on the positive battery post, the black (negative) tester lead is on the fuel pump. The fsm will help if you can find one. What is making you think the fuel pump is not working? If it's not starting you may want to check the coil, it's easy to do. My bike is actually black, it's just dirty right now and poor lighting in the shop.
Schematics for 99 are hard to come by.
The Ignition fuse, gray wire supplies power to the Run/Off switch when ignition is on. turn the switch to run and it powers the W/BK to the start button and to the Fuel pump relay. the relay "Pulls in" and power from the R/O goes through the contact and powers the Y/GN going to the fuel pump. There should be no power at the fuel pump with ignition off.
