Police Baggers Post your Pics, Projects, and Problems in here!
Old 08-27-2022, 04:02 PM
Rip53's Avatar
Rip53
Rip53 is offline
My '04 Road King, last of the V twin interceptors
The following 2 users liked this post by Rip53:
lee4 (08-27-2022), SGT. Sam's passenger (05-01-2023)
  #42
Old 08-27-2022, 08:27 PM
webmax33's Avatar
webmax33
webmax33 is offline
6th Gear
Default 2007 flhp
Here’s my cop king. Was a Philly parade bike before my father bought it and wrecked it.
The following 7 users liked this post by webmax33:
BCLASS (09-04-2022), johndoe297 (08-27-2022), lee4 (08-27-2022), mutedblade (08-29-2022), nevada72 (08-27-2022), Rip53 (08-27-2022), SGT. Sam's passenger (05-01-2023) and 2 others liked this post. (Show less...)
  #43
Old 08-27-2022, 11:53 PM
UrbanRunner's Avatar
UrbanRunner
UrbanRunner is offline
Veteran: Marine Corp
2020 FLHTP - original owner and ordered it from the factory. Extensively modified since purchase.
The following 3 users liked this post by UrbanRunner:
Bhrees (04-30-2023), lee4 (08-28-2022), mutedblade (08-29-2022)
  #44
Old 08-28-2022, 09:08 AM
nevada72's Avatar
nevada72
nevada72 is offline
Received 26,079 Likes on 12,186 Posts
Originally Posted by 14GuineaPig
Orange/Violet = position 7
Gray/Black = 8
Green/Red = 9
Those are the positions in the connector (22B) from the right hand controls for the pursuit switch
If you look at the wiring diagram link that I posted earlier it's on page 13 of 14.
Thank you for that. I connected the orange/violet wire to hot and the running lights came on with the Pursuit switch to the left. I still don't have the low beam, but I can figure that out.
lee4 (08-28-2022)
  #45
Old 08-28-2022, 09:48 AM
Rogue1's Avatar
Rogue1
Rogue1 is offline
2004 FLHPI. Previous owned by New Orleans PD, purchased with 10,000 miles on it. One of the best bikes I have ever owned
The following 4 users liked this post by Rogue1:
Bhrees (04-30-2023), Ericson38 (08-28-2022), lee4 (08-28-2022), mutedblade (08-29-2022)
  #46
Old 09-01-2022, 01:48 PM
lee4's Avatar
lee4
lee4 is offline
Default Problem: Horn not working.
Fix: Trace your hand button horn wire back to the first coupling point for the wire bundles. There, check to see if the (in my 2008's case yellow and black wire) horn wire enters and continues on another matching wire.
If it is still wired for a siren, then your wire will change colors and the actual matching wire will be empty (mine went to a pink line with the matching wire having a plastic peg placeholder).
If the siren wire is not the issue, the wires will match at both sides.
To resolve this horn not working issue, simply disconnect the handle grip side wire and attach it to the port with the matching wire on the other side.
The top pic shows a yellow and black wire coming from the bottom on my handle bar side entering the coupling and from top goes to a yellow and pink wire, incorrectly, for a siren.
The bottom pic shows the white plastic placeholder peg where my handlebar side yellow and black wire needs to me moved. You can also see the matching wire across from the peg.
Apparently this is a very common and super frustrating lazy decommissioning issue.
Best of luck and I hope this saves someone money and time. I scoured my ride looking for broken wires and replaced horns and I hope to save anyone the same purgatory.
  #47
Old 09-01-2022, 03:06 PM
nevada72's Avatar
nevada72
nevada72 is offline
Good tip^^^
My horn was simply not connected. I'm getting ready to hook it up now.
lee4 (09-01-2022)
  #48
Old 09-01-2022, 09:57 PM
nevada72's Avatar
nevada72
nevada72 is offline
I looked at mine and like yours, it has yellow/blk on the handlebar side of the harness, and yellow/pink on the opposite side. On my bike the black wires are in the right spots of each harness - across from each other.
But here's the rub - I figured if I connected my meter to the yellow/pink wire (which goes back to the main open wiring trough under the tank) I would get 12V when I push the red horn button. Nope. In fact, it makes a circuit to ground. So I hook up my meter to read continuity to ground, when I push the button it tones the meter. So I could make this work by connecting one side of the horn to continuous 12V+, and the other side to the yellow/pink. But the diagram shows the black as ground, and I assume, the yellow/blk (and therefore ylw/pink as hot.
Not sure where I'm going wrong here. <EDIT - I found what I did wrong>
As much as I would like to delete and just post my success, I'll leave my mistake here for others to learn from. It's pretty simple - I forgot to turn on the ignition. In the absence of voltage, a path to ground remains. Once I turned the ignition on, I get 12V to the yelw/pink when the horn button is pushed. So it will be quite easy to get the horn going now - yellow pink to one side, and ground (blk) to the other.
Now I just have to figure out the low beam. It's not getting voltage no matter what I do (short of simply bringing an ignition hot to it).
lee4 (09-01-2022)
  #49
Old 09-02-2022, 06:42 AM
00copglide's Avatar
00copglide
00copglide is offline
Here's my 2000 flhtpi...I'm the 3rd owner, she had 33000 miles when I got her in 2010, now 78000 trouble free miles. It was never "in service" the guy i bought it from did a 1550 BB kit with 211 cams, tru duals at about 1500 miles...I've done the cam chain tensioners a couple of times and tbh its been a very reliable ride!
The following 2 users liked this post by 00copglide:
Bhrees (04-30-2023), lee4 (09-02-2022)
  #50
Old 09-02-2022, 07:33 AM
eighteight's Avatar
eighteight
eighteight is offline
Received 4,995 Likes on 2,865 Posts
The following 6 users liked this post by eighteight:
BCLASS (09-04-2022), Bhrees (04-30-2023), gonemad (02-15-2024), Goose_NC (09-05-2022), lee4 (09-02-2022), Toe Knee (05-15-2023) and 1 others liked this post. (Show less...)
Quick Reply: Police Baggers Post your Pics, Projects, and Problems in here!
