Dropped in trans
The story: I was doing a three hole oil change, and drained all holes. Had finished putting the primary and engine oil in and filled the trans.
Had not checked the engine oil level yet but was checking the trans level. I was wearing rubber gloves and had oil on the finger tips, pulled out the trans dip stick and was looking at it and butter fingered it and it sort of did a little bounce and went in the engine oil hole. Some bad words learned over the years came out of my mouth and I know my Tri-Glide was laughing at me for what just happened.
What are the chances of that happening?? Anyhow, tried looking down the hole with a mirror and light and could not see it. I'm thinking, crap if I can't get it out I will have to pull the oil pan to get at it.
So I go fishing with my magnetic retrieval tool and hope the trans dipstick is magnetic and not some Chinese pot metal crap. Got lucky and felt it stick and carefully lifted it and got hold of it with my spring finger grabber tool.
Do not have an issue with posting or calling myself a dumbass when warranted if it helps someone else not to repeat the dumbass. It is always good to laugh at yourself and not take life too seriously.
The following 5 users liked this post by CoolBreeze3646:
05flhtbob (08-21-2022),
hattitude (08-24-2022),
MotoJockey (08-21-2022),
nomoreyellowfootprints (08-21-2022),
Stiggy (08-21-2022)
Trust me CoolBreeze, I've done a ton of "Happenstance" things in my life that made me say, "What were the damn odds of that!!!" I would have no room to laugh at you about something like that, for sure! Those situations are only funny once the issue is rectified, lol. I'd be the first one to laugh at myself for doing it too! Again, glad you got it out easily enough.......
If you have one of these, see if you can fish the tape out. If not it should not do any damage, just get ground up by the gears. Start the bike up, go down the road through all the gears, bring bike back, drain the transmission gear oil & replace.
Just for information, the transmission dipstick will fit through the Engine Oil Fill hole - do not ask me how I know this. A magnetic retrieval tool is your friend should this happen. Now I always make sure the engine oil fill hole is closed when checking the transmission oil.
https://www.amazon.com/Housolution-M...s%2C143&sr=8-2
And if you put a piece of tape over the dipstick to see the oil, how would you read the dipstick.
johndoe297 (08-21-2022)
Uncle Larry (08-21-2022)
