2005 Electra Glide
Old 08-17-2022 | 12:55 AM
pdchi's Avatar
pdchi
Stage II
Default 2005 Electra Glide
I cannot get the rear cylinder to fire when I switch the front cylinder wire to the rear the bike will not start at all put back and now it starts and the front cylinder is firing again. I switched spark plugs and the front fires. I know switching the plug wires should not do anything but it does. Is the right place for this?
Old 08-17-2022 | 03:32 AM
BuzzCap7's Avatar
BuzzCap7
Hi my friend. That was not the right place. No worries. You are now with the baggers. The chaps here are EXCELLENT and likely can help you.
Feel free to come back to the WELCOME AREA ONLY <-- by clicking there and introduce yourself to us.
Stay well my friend,
BC7
Old 08-17-2022 | 06:35 AM
NoRegerts's Avatar
NoRegerts
BC7
Whoa Buzz, no pressure right!?
I'm reading but don't entirely understand. Your rear cylinder is not firing and you tried using the wire from the front on the rear and nothing happened but you know both plugs are working properly? Have you checked the coil with a voltmeter yet?
BuzzCap7 (08-17-2022)
Old 08-17-2022 | 08:10 AM
hd4evr2008's Avatar
hd4evr2008
You put the plug wire from the FRONT cylinder on the REAR cylinder plug and then tried to start your bike? Sorry, but you, sir, are asking for trouble.
MURPHCC1 (08-17-2022)
Old 08-17-2022 | 08:12 AM
MURPHCC1's Avatar
MURPHCC1
How much a one and done?
byersmtrco (08-17-2022)
Old 08-17-2022 | 08:55 AM
mike131's Avatar
mike131
You should have a single fire ignition not a dual fire like the older harleys so you cant switch the plug wires around like the old harleys
pdchi
08-17-2022 04:42 PM
bikerdustin
06-27-2021 10:39 PM
jonpec
EVO
24
06-04-2021 06:10 AM
jamess71
05-12-2014 10:36 AM
chrisparts76
07-12-2010 12:14 AM
Quick Reply: 2005 Electra Glide
