Heel/toe shifter “play”.. how much?
Old 08-16-2022 | 05:38 PM
Rob175's Avatar
Rob175
Default Heel/toe shifter “play”.. how much?
How much “play” (in and out movement) should there be in the shaft that runs from the heel toe shifters thru to the linkage’s lever?
I currently have about a 1/16” of in and out movement. I can loosen the fasteners and push the shift levers in towards the engine to eliminate all space, in-out movement ie: slop but perhaps some slight in-out movement of the shifters and linkage is correct.
I just don’t know.
Old 08-16-2022 | 06:43 PM
702's Avatar
702
You're good. If there is a spec for that I've never seen it but 1/16" is nothing.
Old 08-16-2022 | 06:54 PM
Rogue1's Avatar
Rogue1
Don't sweat the small stuff.
Old 08-16-2022 | 07:04 PM
Rob175's Avatar
Rob175
Thanks for the info and fast replies…… it’s appreciated.
P84WD
07-09-2021 04:12 PM
Wagondog
01-15-2020 06:19 PM
dh_meyer
2014-2023 Touring Models
08-11-2017 09:32 AM
evil_monster
03-04-2009 08:53 PM
wireman2511
03-14-2006 03:48 AM
Quick Reply: Heel/toe shifter “play”.. how much?
