Touring tire pump/repair options
I carry this kit. The pump worked well when I let a guy use it in Sturgis last year.
https://www.amazon.com/Stop-Go-6000-...dp/B0068FX3VO/
I just returned to Vegas from Central WA and boy was it hot. Have a safe trip.
This is the pump I carry:
https://www.rockycreekdesigns.com/pr...or-pocket-pump
You can get it trough Amazon
I can recommend the pump as I have used it several times to help others or top off a low tire, I never had to use the Dynaplug so the jury is still out on that one.
https://www.amazon.com/Rocky-Creek-Motopressor-Compressor-Pre-Select/dp/B07DX98569?crid=1EL49AYW0QR52&keywords=rocky%2Bcreek%2Bmotopressor&qid=1646069004&sprefix=rocky%2Bcreek%2Bmotopressor%2Caps%2C74&sr=8-2&linkCode=sl1&tag=roadrunnerwebsite-20&linkId=fda179f89312764754232bfaff0370a1&language=en_US&ref_=as_li_ss_tl&th=1
And this for plugging a tireI can recommend the pump as I have used it several times to help others or top off a low tire, I never had to use the Dynaplug so the jury is still out on that one.
Thanks for all the replies. I looked at the Dynaplug kit at the local cycle gear store yesterday. I was immediately turned off when the directions told you what to do when the tip comes off in the tire and the plug is stuck in the tool. I'm not interested in carrying a nail so I can extract it.
I did order one of the pumps and plug kits so I should be good to go.
Again, THANK YOU ALL.
Jes
Jes
Would not even worry about it. I live in arizona and ride all year and run my dunlops until they become MAYPOPS and I've never had a problem. There is so much traffic the roads are clear of anything that might puncture your tire.
Be more concerned about someone running a RED LIGHT and make road kill out of you.
TRUST NOBODY
OH YEA, 6 people just got run over Friday....red light...one dead
TRUST NOBODY
The following 2 users liked this post by pointblank:
M Oclaf (08-06-2022),
talkingrock (08-09-2022)
Have a safe trip my friend. Gonna be pretty warm where your riding, but seeing your new addition is gonna be more than worth-while. I also carry a plug kit and a small inflator. I now carry tire inflator. It's compact, cordless, has a digital gauge, shuts off when psi is reached and the air hose locks to the valve stem.
I also have a skinny HydroFlask and use this H-D guard bag.
620Jester (08-06-2022)
TRUST NOBODY
TRUST NOBODY
Brando4905 (08-07-2022)
