bike is stalling
Old 08-06-2022 | 08:27 PM
Rounders's Avatar
Rounders
We don't know if FI. But coasting down with FI and dirty IAC can stall. Not sure it effects 4 and 5 gear.
Cycle on off can hear Iac motor, spray cleaner in to hole about 10 o clock behind air cleaner.
Seemed to be more of an issue with later bikes. I need to do mine around 10kmiles. Never noticed it at higher speeds
OkieBill (08-07-2022)
Old 08-07-2022 | 08:11 AM
skyhawk940's Avatar
skyhawk940
03's had a problem with short/tight fuel injector wires. The conductor breaks inside the insulation near the injector plugs causing an intermittent miss. Replaced both plugs and no more problems! I got DELCO plugs, about 1/3 the price as HD price..
Old 08-07-2022 | 09:20 PM
Mr. Mike's Avatar
Mr. Mike
And of course if it’s a carb, plugged jets/air passages can cause idle stall and at speed misses. Eliminate what you can, and if you’re not up to YouTubing a carb tear down (if it comes to that), find a reputable local shop to do the work for you.
Old 08-07-2022 | 09:49 PM
Rounders's Avatar
Rounders
The guy creates the post at 10:51 am yesterday, and last on 11:07. I get it people are busy, Other things going on. But we need some input from him. As in carb or FI.
Old 08-07-2022 | 09:57 PM
shaggieshapiro's Avatar
shaggieshapiro
He doesn't have a bike,
Old 08-07-2022 | 10:47 PM
johndoe297's Avatar
johndoe297
He must not want an answer that bad. If he is not overly worried about it why should you be?
Or he could be busy like you say.
Or the bike could have stalled at a very bad time...
Old 08-08-2022 | 07:39 AM
Rounders's Avatar
Rounders
I agree, other things in life pop up.
sbergerson
07-29-2014 11:22 AM
preksy
05-20-2013 02:15 PM
Road King Dreamer
07-26-2010 04:50 PM
wood808
03-12-2010 07:09 PM
roadkingkat
03-07-2010 04:16 PM
Quick Reply: bike is stalling
