$139 for a SE a/c kit ... wow!
Old 08-15-2007 | 09:37 PM
SSZ7D's Avatar
SSZ7D
Default $139 for a SE a/c kit ... wow!
i was at a harley shop last night talking with a parts guy and he showed me the SE a-c kit and it was $139, lot of money for not much, some kind of k&n type filter, backing plate (cast) and not much more
Old 08-15-2007 | 10:03 PM
gman's Avatar
gman
Default RE: $139 for a SE a/c kit ... wow!
Don't get it! Go with the AN Big Sucker! Much better design on the backing plate. I have them both, and the AN, IMHO, is the better of the two. It also helps on oil misting through the AC, which the SE doesn't.
Old 08-15-2007 | 10:12 PM
tlb's Avatar
tlb
if you order it seperate pieces you can get it for less than 90 with the kn filter. there is a thread on here with all of the parts numbers something like "poormans stage 1 ac"
also dont for get if you get it and you have changed your exhaust you will need to retune your ecm for the increase air flow. pm me if you cant find the thread.
Old 08-16-2007 | 11:02 PM
gilbos440rt's Avatar
gilbos440rt
I got this off E-Bay lot better deal than the SE a/c http://cgi.ebay.com/ebaymotors/ws/eB...m=140114982793
Old 08-16-2007 | 11:07 PM
SoCal_Pappy's Avatar
SoCal_Pappy
E-Bay "BIG SUCKER" with Chrome backing plate - $119.95 SHIPPED
Less $$$$ Better Product!!!!
AMERICANCLASSICMOTORS
Old 08-16-2007 | 11:46 PM
iclick's Avatar
iclick
ORIGINAL: SSZ7D
Not only is it overpriced, but its filter element isn't cleanable. Buy the K&N or the Ness Big Sucker, the latter being cheaper--both of which have the K&N cleanable filters.
Old 08-17-2007 | 12:07 AM
sleepyjim's Avatar
sleepyjim
I got the rk-3909 K&N a/c kit off ebay, dam cheap.............
Old 08-17-2007 | 05:02 AM
PapaTravis's Avatar
PapaTravis
before I found this forum, I got the SE a/c, and regret that. I have since added aK &N element, and will need to get the chrome back plate, to run with an open element. It would have beed cheaper for me to get the chrome ANBS.
Old 08-17-2007 | 09:38 AM
Garemlin's Avatar
Garemlin
I too pieced together the SE kit and then bought the K&N filter. When I ordered the pieces I got the chrome backplate in place of the grey. Everything came to under $100.
Old 08-17-2007 | 10:54 AM
gwcrim's Avatar
gwcrim
Ya might call me crazy but I don't want my oil vapors routed into the intake. I just bought a used SE s/c that gives me the option to route the breathers through a rubber hose down to the ground.
Reason I do this is that I tore my Sportster apart at 11k miles and there was a very horrible amount of gooey carbon build up in the exhaust ports. I bet the ports were 10% blocked. From that point on, I've always vented the breathers out of the a/c.
Quick Reply: $139 for a SE a/c kit ... wow!
