2019 Road King
Old 07-13-2022 | 06:20 PM
joelinares's Avatar
joelinares
Stage II
Default 2019 Road King
I got a 2019 Road King, just under 30k miles.
It has rattle in idle and in drive, rattle seems like it comes from the rear end and is very apparent when you give it throttle in idle.
in first girl there is grinding but it shifts fine and rides fine. Sometimes when shifting I値l get a pull but that could just be user error.
Rattle can be heard through all gears at all speeds, however first gear the grinding is very bad. 2nd year the grinding is bad as well and I知 not to sure about 3-6 for the wind starts muffling my hearing.
I suspect it痴 a tranny issue but I知 not entirely sure.
Old 07-13-2022 | 07:52 PM
TracerBullet's Avatar
TracerBullet
Welcome to the forum
Old 07-13-2022 | 08:02 PM
702's Avatar
702
Have you checked the primary and trans fluid?
Old 07-13-2022 | 08:04 PM
joelinares's Avatar
joelinares
Stage II
Yes swapped with fresh fluid, minimal shards nothing major whatsoever.
Old 07-14-2022 | 03:53 AM
kojak's Avatar
kojak
Check the mounts and clamps for the mufflers.
fastmartin
04-19-2022 11:31 AM
Road Star
09-25-2018 05:08 AM
rcamp01
05-04-2015 07:37 AM
boneyard75
07-09-2013 01:34 PM
S8NSW8N
08-26-2009 03:10 PM
Quick Reply: 2019 Road King
