heat?????
Old 07-12-2022 | 04:59 PM
dklaus's Avatar
dklaus
Stage II
Default heat?????
Has anyone had a hard time starting. I had power it just took about 5 min to crank over
WVHARLEEMANN (07-12-2022)
Old 07-12-2022 | 05:13 PM
Keithhu's Avatar
Keithhu
Welcome to HDForums, from Michigan.
1928 JD two cam? Panhead? 1995 Fat Boy? 2007 road king? A little info helps. Year, model, mods, miles, etc.
Y2K (07-12-2022)
Old 07-12-2022 | 05:14 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!
Old 07-12-2022 | 05:20 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Congratulations on your first post to HDF to the forum.
One of the better first posts I have seen that mean absolutely nothing without further information. Maybe list the year and model of your motorcycle and maybe a picture.
I'm old and have a hard time starting also, mostly in the morning before I get my coffee.
All my motorcycles start just fine, cold or in the heat. Hope you get your problem solved.
Maybe do a little maintenance on your battery, cables, etc. and see if it helps.
Old 07-12-2022 | 05:24 PM
dklaus's Avatar
dklaus
Stage II
2002 road king no mods 52000 miles
Old 07-12-2022 | 05:25 PM
squirrelsnest's Avatar
squirrelsnest
Welcome to the forums from Virginia................
Old 07-12-2022 | 05:34 PM
Taxgod4u's Avatar
Taxgod4u
Need to pull the hot start lever.
Old 07-12-2022 | 05:39 PM
Cosmic Razorback's Avatar
Cosmic Razorback
I would look closely at your muffler bearings.
Old 07-12-2022 | 05:41 PM
GalvTexGuy's Avatar
GalvTexGuy
When was the last time you changed your blinker fluid?
Old 07-12-2022 | 06:37 PM
memphisharley's Avatar
memphisharley
Veteran: Marine Corp
5 minutes is a long time to be cranking over. don't know if a brand new fully charged battery could withstand that.
as stated..post the info the forum members need to assist you.
good luck with her
MotoJockey (07-12-2022)
Quick Reply: heat?????
