2002 flhrci
Old 07-10-2022 | 01:58 PM
JimmyJjammz's Avatar
JimmyJjammz
Stage I
Question 2002 flhrci
Bike will prime up and start but what causes it to not continuously run? I've been told a bad TSM which goes along with the security system. I also installed some aftermarket Halogen lights up front, think incorrect wiring could be the problem or burn that TSM out? Stumped. Bike collecting dust
Old 07-10-2022 | 02:24 PM
GOGOBECK's Avatar
GOGOBECK
Check the battery voltage.
I had the same issue on my ‘01 FLHRCI
The voltage was just a tad low… the same battery works great in my ‘97 carbed RK.
Old 07-10-2022 | 02:28 PM
Fireball Jack's Avatar
Fireball Jack
With just this info no one will be able to help. But I will take a guess, bad orange mans tweets are to blame. Due a bit of trouble shooting and give us some info.
Old 07-10-2022 | 02:49 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
you either have a TSM or TSSM, If you don't have some sort of a FOB, you don't have a security system.
A TSM won't do anything to keep the bike from running.
not running at idle after starting or not running when you give it fuel?
if you open the gas cap then turn the bike to run so the fuel pump primes do you hear anything but the pump running in there?
Bad hoses in the tank are not uncommon, a bad pressure regulator is not out of the question.
If you were daring you could see if it keeps running on starter fluid... LIGHT HITS of starter fluid as the bike starts sputter should do it....
Which brings me to does it sputter and stall as if it is running out of fuel or does it just quit as in electrical.
What do the plugs look like? Black and sooty is a sign of bad spark
Old 07-10-2022 | 03:24 PM
euchre98's Avatar
euchre98
check for intake leaks. If it dies when it warms up that’s your first clue.
gonzosc1
05-17-2018 05:50 AM
burnabybill
General Topics/Tech Tips
09-09-2013 12:52 AM
ChristoHD
04-19-2012 02:55 PM
faber
12-04-2010 02:21 PM
Quick Reply: 2002 flhrci
