Let me see your Fog/Driving lights
I ride to work as much as possible, especially now that gas is insanely expensive. Well obviously it’s dark at 3 am when I leave the house, and although my headlight puts off a nice beam right in front of me, I would like some more light to the sides. It seems like when I get off an exit and go into a sweep the beam just doesn’t hit the sides (that’s what she said !!) I’m thinking of mounting something down on my crash bar…most likely some fogs or at least lights with a fog beam option, as we have a lot of it in the spring and summer months in the morning. So what are y’all running? I’d like to see some crash bar mounted lighting… I have a ‘19 SGS, so it has the chopped engine guard…
You might want to look into some Clearwater Darla's. Yes, they are expensive.
https://www.clearwaterlights.com/pro...-electra-glide
The following 2 users liked this post by LQQK_OUT:
fullautomike (05-26-2022),
kunzjob (05-26-2022)
Some good choices here.
LQQK_OUT - do you have any pics of yours installed ? Work good? I checked out the link you posted and like what I saw. I also found these by Ciro, they’re called Tac10 Light Cannons, for about the same price as the Clearwaters, and they come with mounting brackets for the crash bar and wiring. KC HiLites has some nice stuff too that would work as small fog lights, and some brackets that I think would work. Price is better than the two brands above too. Thanks for the ideas and keep them coming please (with pics if you got em)!
Custom Dynamics Probeam Fog Lamps. I wanted extra light at night and more daytime visibility without changing the appearance of the bike too much. I ran the wires inside the crash bar and I custom wired the lights so that I could use harley's dash panel switch to operate them. The halos run continuously, the center of the light turns on or off with a switch that is part of the wiring harness supplied by Custom Dynamics if you don't change anything.
front view. Harley LED adaptive headlamp, Harley LED turn signals, Custom Dynamics Probeam fog lamps
fog lamps just clear the lower fairing
headlamp halo and fog lamp halo are on. the centers are not on, because then they are too bright and the pictures are a mess
The following 4 users liked this post by coop creek:
