Fuel Tuner on stock bike?
I would just wait until you do a stage 1 or swap a cam. A "tweaked" tune could give you better throttle response and a slight increase in performance if tuned properly but I doubt you would notice it enough to justify the cost. Stage II with a good tune is the best bang for buck you can get.
The following 2 users liked this post by RET_SCPO:
NorthWestern (05-21-2022),
Silent Glider (05-21-2022)
The following 2 users liked this post by predatornut:
14 FLHR (05-21-2022),
Notable is not just the peak numbers but the fact that the tuned bike decays less in the higher RPMs. The different stock exhausts may have something to do with that.
Silent Glider (05-22-2022)
I had a Power Commander 3 on my stock 2003 before the PC3 and a replacement crapped the bed and I went to a Thundemax and cammed the bike.
IMHO every HD bike can use more fuel, even if it is stock.
There are people who disagree with me, especially when it comes to M8's
If you are planning on upgrades, just get a tuner you know you will be able to re-map to fit what what you think you are going to do in the future. as mentioned above buying from a supplier you know is going to be around and able to help you with maps is important.
YMMV
YMMV
Yes - They all are tuned too lean from the factory - that is one of the reasons they run hot - a tuner will help
Is it worth it to you ? I can't answer that -
I got a Daytona Twin Tec years ago because I know I would be making changes - and would be able to change the tune as needed
Lets back it up, since what stock bike, since may not need a tuner to tweak the tune to start with.
If older evo and already had the ECM swapped out with a S&S unit, then all you need is the free software to re-tune the ECM from them instead.
But yes, HD sends the bikes out on the lean side to meet EPA standards, so they runs hot as hell, since it's tuned so lean to start with (fuel is cooling).
On the 2016 Dyna I had with the 103, I got an FP3 before I did intake and exhaust, and flashed the improved stock tune. Let me tell you it ran much much better. Less hesitation, just generally smoother at all rpm’s. If I ever bought a bike and intended to leave it stock (not likely lol), I would still get some sort of tune on it. They run much better when not forced to run the EPA mandated lean stock tune.
Just my opinion.
Just my opinion.
