adding oil
Received 1,296 Likes
RE: adding oil
Go to the tech section, get into the oil forum and start reading. I wrote a 2 part article on oils and it's there in the top section. You do not have to use HD oil, do not have to use diesel oil, and can use the correct viscosity car oil. There are better quality oils than HD, and for a much lower price. If you use the correct viscosity oil, you won't void the warranty.
RE: adding oil
I'm not sure if the HD clutch is the same as a Sportbike, but you can NOT use any oil with MOLY in it. If you do it will cause the clutch to slip. Moly is usually found in automotive oil.
Just a thought, Like I said I'm not sure if our Clutch is the same as a Sportbike.
I would stick with an oil made towards the motorcycles instead of automtoives.
