These are photos of my 2022 RKS before I changed shittty stock bars with KST 12" Straight Jackets. After trying a longer upper LA Choppers cable that said would fit(it was way to long and would not fit inside nacelle and was generally crappy quality),.I reinstalled stock HD cable and routed it as stock and added a FBI 4" cable extension. This worked the best if you want to keep it as stock fitting as can be. I may try a longer(+4") upper Barnett cable to eliminate the longer cable "tube" that comes with the FBI cable extender. Hope this helps.
Safe travels Stock wire and cable on 2022 RKS Stock cable and wire 2022 RKS
