Charging problems
Charging problems
2015 Road Glide Special
Before I tear this thing back up thought I’d see if I just did something wrong.
I just replaced my stator and regulator after noticing the stator plug at the regulator was showing signs of arcing. I had no charging issues. After I got the new stator and regulator in, my bike isn’t charging. I tested the continuity and it’s showing ground between the 3 poles and ground pole to frame. But when I check the output I’m getting 22 VAC at idle.
Anyone have any idea what to check? New battery and fuses are good.
thanks
thanks
thanks
thanks
