New GTS radio but no CB
Old 04-16-2022 | 07:33 PM
Ssitruc's Avatar
Ssitruc
FWIW, Here are my bike's settings...
Old 04-16-2022 | 07:44 PM
mstrobes's Avatar
mstrobes
I'm going to the dealer Tuesday. thank you for the settings
Old 04-16-2022 | 08:04 PM
Hammz's Avatar
Hammz
Originally Posted by Cosmic Razorback
Nice update. Not sure which year it was that HD quit putting a CB as standard. My only guess is the new GTS does not recognize the older CB modules?
Do you actually use the CB? It’s only been turned on once on my bike and that was by accident.
Good luck getting it worked out.
The GTS radio DOES recognize the CB. I did this upgrade the first month the H-D upgrade was available.
The problem here is the dealer doesn't know how to flash the radio to recognize the CB. If they can't figure it out, find another dealer that has techs that know what they're doing.
Also, you should get the CB & CC functions swapped (put CB function back on the left side, CC function on the right). This mod is done with Tech II tool too. After reprogramming the modules, just pull the switch covers off & put the back on the other side (no tools required to make the switch covers swap).
Old 04-16-2022 | 08:22 PM
Hammz's Avatar
Hammz
SSITRUC -
Interesting Diag4Bike menu list. Looks way less complicated than Tech II screens I've seen. I also see the option is still there to allow the external GPS systems (that were standard on some CVO models & available in P&A catalogs (Road Tech Zumo 660 & 665) from pre-Rushmore years to be fully integrated with the newest radios (Audio Input 3 - Interrupt Tone Detection). Nice.
Old 04-17-2022 | 12:09 PM
Ssitruc's Avatar
Ssitruc
What I wish, is that they had a manual that went thru all the screens and told what each item was and what the available options are... None of the 3rd party programmers do a very good job of that.
For instance, I THINK "Digital Audio Broadcast" should be enabled on mine... but I am not sure, so I have left it alone. There are so many more things on the other screens that I wonder about too
But I know what I know, and more important, what I don't know... so for me, "I don't know" means leave it alone.... everything's working, so I don't just keep fixing it until it's broke...
Old 04-17-2022 | 01:01 PM
30glock's Avatar
30glock
I also did the upgrade when first available, works as intended on my 15 CVO RGU, congrats on the upgrade.
Old 04-21-2022 | 06:30 PM
mstrobes's Avatar
mstrobes
Update, dealer reflashed radio, CB frequency change from FM to AM. all good
The following 4 users liked this post by mstrobes:
GalvTexGuy (04-21-2022), hattitude (04-25-2022), lefty33 (04-21-2022), Ssitruc (04-22-2022)
Old 05-21-2022 | 07:10 PM
ardakota's Avatar
ardakota
Does anyone have the screenshot of the digital technician where the am frequency is? I think I may be set on fm frequency and our techs are not real good at cb.
Old 05-22-2022 | 10:42 AM
Ssitruc's Avatar
Ssitruc
Posted one in your other post (post 12)
https://www.hdforums.com/forum/audio...ly-static.html
Aaron Tyler
Screamin Eagle CVO Models
36
08-28-2024 06:29 AM
alfa4711
03-23-2023 08:21 AM
Keithholly
09-25-2019 05:37 AM
Twotone2t
03-10-2019 11:07 PM
Scaredofrain
Audio Systems
07-19-2015 01:35 PM
Quick Reply: New GTS radio but no CB
